You laugh now, but when I'm at a formal occasion with a shitty DJ and they need someone to drop Dre beats...I have something up my sleeve.
You probably tell that one to everyone who asks...
  • Like 1
Is there some sort of liquid in the tin when you take the spam out? Cos if so you could actually make a spam reduction
Surprised you have not tried it before
There is some sort of jelly that is slightly watery
Spam itself is oiled enough that you don't need a non stick or oil to cook it
Yup. Drop the wages. That'll make people want to work in the middle of a 50 degree desert
Problem is that people have built a lifestyle around the income & any pay is better than 0 pay.
Lot of small cap miners have gone into care & maintenance mode so there are a lot of people looking for any work.
I've been told I'll be changing to 8/6 roster from my 9/5 roster. Will be losing $20,000+
If my Maths serves me well then you're currently...
156-157k pa?
VWLBC leader
156-157k pa?
VWLBC leader
$20k is what hr has told in general for everyone in the office. No idea what it means for me. Could be more, could be less :P
Also your estimate would be excluding superannuation & bonus
I think you've told me before actually but I forget...
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
