Nah it's deliberate. You ever see someone stack whilst skiing and hold onto the poles for the whole time their wiping out? Don't think so.
You could be right, but he ain't skiing and I reckon he's holding onto it because there's a $400 gopro on the end of it.
You ever seen someone trip over and smash their face, stand back up with their beer still in tact in their glass?
So...chose Jupiter ascending...because milana kuntis....and reviews said movie was crap so at least I am prepared for disappointment
Should have seen Theory of Everything
Some GoPro selfie sticks have wrist straps... once again because you've got half a grand worth of GoPro and accessories you don't want floating down a river or falling off a mountain
Have done it many many many times
If i pay for a.big cinema experience I want a big cinema movie...
Big sounds and special effects, lots of action scenes and excitement..
A nerd n a wheelchair is the same experience regardless where you watch it
Btw movie was ok...
Edited by ARTZ
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
