What did liberal get right today? I'll tell Ya!
Abbott is spot on about not funding remote communities they have no right to go live north of bum fk Idaho and expect gov support - the fact they are aboriginal or not is irrelevant
I bet if there were Christian councillors in the schools he would fund it like Gina Rinehart on an everlasting cupcake
  • Like 1
is there a steam repository in AU (never used it so no idea)
as if not you would never get close to maxing the connection out anyhow.
Yeah they do. Ive only ever hit a max 1.1mb/s but that was in clayton on ADSL2
thanks man! im going interstate, so anything that looks decent will be great!
shit dude, QLD?
ill check my garage see if i have any spare moving boxes.
A few years back when I had to care about internet quota, I ran a program on my PC which tweaked some firewall rules to block the Non-Bigpond Steam Content Servers... Sometimes it stopped games / updates from loading if the server was too busy (since it couldn't switch to an alternate), but when it would download it'd be Unmetered Data.
Not sure if that's still a thing... but yes, Bigpond, Internode, etc do run some steam content servers to reduce traffic
im with internode and get unmetered steam. its been a god send
pleaseee you know it's bs funding the petrol sniffing outposts that provide zilch to the economy
This
Here are some cliffs so we can just skip it
Hamish quote's Alex's post, reminding him that his beloved Liberals killed the NBN and that he should blow Tony Abbott; Ric comes in with a clever jibe lined with anti ALP sentiment but hardly anyone gets the reference; Hamish pretends to be non-partisan and no one believes him for a second; Al attacks the lazy working class and anyone who doesn't pay a lot of tax including puppies with cancer; Dezz calls Abbott a cocksucker, then somehow gets a payrise for blocking roads in the city
haha so good.
i just pay the $110 and stay at the Benalla caravan park. much better/easier and still get to sleep in own bed saturday night
also, f**k australian games classification. have to pirate Hotline Miami 2 (as per instructions from developer) because the 8-bit looking game didnt pass R18+ classification.
for anyone else keen: https://kickass.to/hotline-miami-2-wrong-number-t10331590.html#main
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
