Hmmm that one can sometimes take the input shaft with it, hopefully not yet and it's just on it's way out.
Outside chance, but can also be a clutch issue. Thrust bearing another slight possibility if it's rattling around on the input shaft retainer because it's slightly touching the pressure plate (a good way to test out this one is to put a small amount of pressure on the clutch pedal so that it presses the bearing firmly up against clutch, but doesn't engage the clutch...if noise disappears then it's probably this. Otherwise input shaft / spigot bearing is your culprit.
Might as well do rear main while you're there too.
Any IT gurus here can point me to a cheap/free webhosting service?
Just need a service with cPanel so I can setup a catchall email forwarder.
cheers
I've used crazy domains in the past, seemed decent.
Stop being irrational
Ordinally, I'd intercept here with an acute pun/expression derived from mathematics, but my obtuse, two-dimensional humour oddly does not appeal to the lowest common denominator, only outliers like Ric and even yourself...plus I don't want to be mean and ruin the mode, so I'll be a square and stay out of this 1. But I regress.
  • Like 2
We're very proud to make you a member of our very select group. Welcome to Super Friends.
Welcome, Super Friend, I am called Ham, because I enjoy ham radio.
Missus dad hired skip. filled it up to level on sunday.
Wake up monday morning and theres a shit load of crap on top + bathtub and hot water system.
What the f**k.
What did you expect...skip belongs to the neighborhood between 7pm and 7am
  • Like 1
If it means me waiting more time to get in cause your car gets priority...hell no
Nah mine will take at least 6 months we're predicting as customers will always take priority no matter how late they walk in the door through my build :P So I'm currently in the process of buying a daily for the long haul. Theres 3 engines being built in the engine room atm, all of them RPM 2.8s. I was merlin when I walked in and saw 3 new crankshafts all just sitting there..
*ahem* engineer whose specialisation is statistics checking in & you reference the lawyer
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
