Pat how'd you get on?
no call back after my expiry date of yesterday. Guess the vendor willing to gamble it for an extra $10k.
Not fussed, im happy to live across the street if the house is better.
Using the postcode to drive up the price seems a bit superficial when the house is on the border of the next suburb lol
wow that's fkd up. Agents like that never succeed long term cos guess who you won't call when selling in the future?
Plenty more out there im sure
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
