Then I realised I can do these things :P
crown wheel bolts used by eleventy models so that's no good. HOWEVER half shafts are only shared with R34 RB25DET MT so there's your best bet for a bolt in diff centre.
seems like a lot of moolah for just a centre... when i would consider even a viscous diff to be an upgrade.
maybe when i need to get rid of a lot money quickly... and then ill also grab these to fill the wheels
http://www.tunerwarehouse.com.au/index.php/products/product/view/125/1405
odie's D2's looked good today. i'd want low dust brake pads though, EBC seem to do some for D2's but the EBC daily driver pads ive got now make a bit of dust
Lol, grab a 34 Viscous, shove a 38424-40F67 shim in there, call it good :P. R34 also came in torsen LSD too. I think Alvin has one kicking about?
whats the washer do? after seeing Charles' torsen diff in action i dont really want one :P
sub 1:30 is solid time, especially for sub 200kw cars (except for 86's on semi slicks)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
