from what i saw when I went to interviews my bike was better than em all lol
mines pretty light too.. wouldnt be hard lift front wheel with 2 people on the back of a van, up it goes.
if parked on street / footpath I'd almost make a bet that it'd be gone :P already had 2 stolen off me
Edited by UNR33L
Got schooled by Winterbottom on a Phillip Island racing sim
1:54 vs 1:41
Surprised how well he did; those sims can be counter intuitive to real drivers. Obviously pays to know the track well
1:54 vs 1:41
I would have expected this
  • Like 1
Fictional is all the more reason to claim it; no real world result to back it up
Lucky for Frosty it wasn't a real track or my GTS-T with KU31s could have rekt his contract renewal chances
  • Like 1
I wonder how you would go driving a real car (with a dog box) like a daytona car?
I mean, I know you would break it but how long would you last before removing gears from your legs?
Need a cassette type transmission like a bike
That would be a big advantage to building one of those motorbike engined smart cars, instant clutchless sequential shifting
haha no need for brakes, just downshift & drift. dayyytonaaa
  • Like 2
nope, unless its been replaced by some dodge bolt from bunnings that is more likely imperial not 11mm
I think there's an 11mm bolt holding the crossover pipe to bracket on RB25...could be wrong, it is the internet afterall
Edited by ARTZ
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
