When I picked my car up from Creatd (wow that dates this story) on the walk from the station at 3:30pm I reckon I saw like 10 commodores come out of factories sideways spinning a singular wheel
Edit: that's totally a lie... but I did see 3 which is a lot when you think about it
I live in Frankston...I see this daily, dont even need to leave the house... :rofl:
f*k cats.
at least guinea cops or rabbits mow the grass.
Got sum bad nuwz Leigh
Whether you want a cat or not you got a cat lady brah
No way, I'd boot it over the back fence
On another note, my family dog is getting old :( like 15 years old had him since grade 6.. dem feels
Edited by UNR33L
Was at ferntree gully Nissan just before waiting for the parts guy on the phone... Someone putting rb26 in a gtt by the sounds of it ... Guy was explaing to the customer than the N1 model stood for nurgburgering.
Well done
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
    • Doing a +T on my car and I’ve read the precious forums lots of mixed reviews from sometime back.  checking if anyone has any ideas for airbox or enclosed pod filter or solutions?  I was thinking stock GTT box but some say it’s restrictive? I seen some people try fit in a pod in the box anyone done that recently?  not any good enclosed options ? Thanks
