That was the other thought I've had... 32 gtr club regd and off its dick. But being so old I'd wanna pretty much replace every part of it... I'll just end up getting something much newer... One day
Just a thought, 1995 R33 GTRs are 20 years old now, could do that so you don't get aids interior
edit: oh just realized it has to be 25 years not 20 :(
Edited by UNR33L
http://www.heraldsun.com.au/leader/outer-east/a-man-who-took-an-innocent-selfie-at-westfield-knox-has-his-image-splashed-all-over-facebook-by-a-mum-who-thought-he-took-photos-of-her-children/story-fnrwkhlp-1227342634069
Story about some innocent man at knox shopping centre getting grilled on FB
Saw this on FB with people on my list. For the Knox suburb, South east brahs
If I was that bloke I would have plastered her face all over Facebook and just labelled her a karnt.
Simon 100% no passenger laps tomorrow? I wont bring my helmet then!
Dezz what company do you recommend for phillip island track days on the bike? thinking of taking the MV around.. fun times into turn one?
FArkn bored house wives are a scourge on society
  • Like 1
But then you'd be in the news, ACA, herald sun, 60 minutes and a jail term too
Reminds me of the bored old hag that had a go at me for parking in pram parking, f**k off bitch there's a heap of spots around
I'd think you'd be a dick too, just like people parking in disabled spots :/
Saw an ad for an upcoming ACA story lastnight
The people who dress poorly for their court appearances...frustrating and angering magistrates left right and centre...and why you should be concerned about this!
inb4 expose on the common cold and why you should avoid getting sick
As I am sure I said last time... THIS is why no one likes Gen Y
  • Like 1
Now that's an ACA story I can get around Edited by HEKT1K
Why are they so angered by the dress code?
Shouldn't determine if you are guilty or not.
I can understand to a degree magistrates getting upset at people not dressing nicely for court...not that everyone can afford to...
But why ACA give a shit or think the public do is beyond me
Fair enough
But lets not diverge from the topic at hand that Leigh is a karnt
Sounds pretty good to me... means if I ever have to go to court for something and I wear a suit, I'll be recognised for the upstanding citizen that I am...
Ric can I borrow your pink knickerbockers?
So hard for the stupid bitch to confront him in person about it and give him a chance to explain
Better to shame him on social media and people make their accusations
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
