Free service. They make commission off the loan referral.
Correction they get an upfront and trail commission for the life of the loan. In short you pay them heaps.
Unless you refinance with a bank / someone else.
I'm at 4.49% happy with that for my loan amount
  • Like 1
But then I calculate the difference in interest on my current rate of 4.75% to something like 4.5%, and it's like $20-30 a month... so can I be f**ked? probably not lol
Well $30 per month x 12 months x 30 years = $10800
Jus sayin
Anyone know of someone to rebuild/refurb my steering rack?
National Power Steering want $750 for an exchange unit. Maybe if it was for a lambo I'd pay that.
Cheers
National steering quoted me $430 back in 2010.
I took mine to Revzone to swap in/out.
He quoted me $415 with a 24hr turnaround service. Not sure who he used.
All you mother f**kers getting these low ass rates while I get raped
well you could just call a broker they'll literally do it all for ya you'll get a good as rate too!
or blame hamish. He is the face of these horrid institution who oppress the poor. /leftylogic
No that's idiot logic.
Both sides of politicts know we need banks
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
