Haha I doubt it. Given the premium he paid for the land I'd say he's after the actual location instead of trying to make a profit. House is pretty bespoke too
There's one up the road on similar acreage that has been vacant since the early 90s (Chinese-Australian owner lol)
They should give him and other members a payrise. If he wants his first home to be in Kew then he should be given every oppurtunity to make that a reality.
Scratch that his a liberal mp apparently.
Ol mate hockey have to chip in for him
Edited by alr33x
http://www.businessinsider.com.au/mother-of-two-calls-out-treasurer-joe-hockey-with-an-open-letter-doing-the-maths-on-sydney-housing-affordability-2015-6
Poor woman had to borrow money from her family to buy her first house...shock horror
Uses as an example the most expensive housing market in the country weighed against the average nationwide wage for a single university graduate
#leftylogic
Why do people think being able to easily buy an inner city property as a single person with any old job is a god given right? And when did this mentality begin? I can't remember my parents wanting to live in Toorak on average wage - they bought on the fringe with decent jobs, which 35 years later happens to be a very good area...now!
  • Like 1
I couldn't make it through the whole article. The phaggotry was too equisit... even for a chef with a decade in fine dining...
“I’m not Jesus. I can’t turn water into wine. I’m more like David Copperfield. I can do magic with water,”
Pls die
  • Like 1
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
