Birds you love those mount dande hipster cafes, always sending snapchats from them :P
Rode past a few today might of been near ya
And agree to what you said earlier, I'm not on the baller vic wasteland dat dere' 6 figure salary, compromised and got a 2 bedroom unit a bit further out than initially looking.
Too many dreamboats wanna live Caufield / glen iris / bentleigh in a 5 bedroom house then complain that they're ~1mill and cant afford.. bitch pls just go a bit further out and downsize.
Edited by UNR33L
  • Like 2
can't view :(
info.png?release=233YOU'VE REACHED A SUBSCRIBER-ONLY ARTICLE.
Would you like to become a subscriber for 50% less for the first 12 weeks?* Sign up now and access the full breadth ofThe Australian's content in minutes.
Hahaha I was up there today at said cafés and feeding the cockatoos.
Did you come from Belgrave direction by any chance? Saw a fair few bikes out there today. Dat mountain run we used to do, I smash it so much faster in my car than I did on bike.
yeh we had about 6 bikes
So was that you heading in the opposite direction when I was stuck in traffic on the way to Belgrave?
Damn I miss riding...bought 2k worth of gear like a month before bike got stolen :(
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
