Or get a cheap hand operated fluid transfer pump from bunnings and stick the line as low as you can get it in the tank (does require opening it up, not sure where they are on a pulsar or if they're a bitch to get to) and pump it out yourself.
  • Like 1
I remember walking into CBA as an 8 year old with $250, young VWLBC, and saying bitch these are my outboard motor savings for my dingy, put them in my account; yes that's my signature, I'm too young for a consistent signature, now give me some damn interest.
True story
