Old CEO came into my office
Didn't disrespect my whole family
Instead says thank you for my contribution to the company that recently sold
Generous mofo...that's all I can say
So the prime minister is going to "do something" about Q&A. Cos that's in his job description now apparently
Not really sure he understands this whole freedom of speech deal the free world has going on.
i get what you (and everyone else that has ever heard of the ABC) are trying to say... but lets really get ready to be real here... the ABC has cut sick at the liberals (JJJ, ABC radio, newsrooms, Q&A, 7:30 report, Clark & Dawe) for possibly removing their jobs and their friends' jobs. theyve been dishing so much hate its almost like reading a newspaper. ABC is supposed to be our go-to people for fairness in news and politics. you dont get it anymore.
I'm not sure the Q&A audience understands it either
When did I miss the referendum where we decided disagreeing with the government makes you a "lefty lynch mob"
If this government want so abhorrently conservative we also wouldn't be in this position.
People who live in glass houses....
Referring to son of rajab flogmatron the other night or in general?
In general
If anyone who isn't a pro Muslim pro feminist pro gay pro JJJ activist voices an opinion to the contrary of these, en cue the boos and hisses and shouting down from the rest of the leftis panel usually made up of a feminist blog writer, a female token politician, a shadow cabinet minister and some random old guy who doesn't know why he's there...oh...Tony is his name
In general
Yes the audience is usually biased to the left as you would expect, but I don't get the constant complaining about the panel being all left as it's simply not the case
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
