The ABC are in clear breach of their statutory obligation to be balanced.. this comes with being handed $1,000,000,000 each year by taxpayers, the majority of whom are not of the Left
If it's privately funded, slag the Libs all you want eg. Fairfax. By the way, how's their share price / circulation tracking?
  • Like 1
I strongly oppose my tax dollars paying for the likes of that Louie Mccerty (not even gonna waste my time googling how to spell his name) cocksucker. Or a Doctor to answer the pointless questions of a bunch of stoned f**kwits with too much time on their hands
Yes the audience is usually biased to the left as you would expect, but I don't get the constant complaining about the panel being all left as it's simply not the case
When the host who decides when people start and stop talking is as subtle about hiding his true leftist nature as you are, it doesn't matter how balanced the number of panelists are.
The audience also ruins it because all someone has to do is include a populist and unrelated statement in their argument at the end and are met with thunderous applause drowning out any chance of rebuttal from their opponent. Cue Tony saying moving on now...
Show would be much better without the audience and if panelists had a set time limit to what they said and weren't allowed to be interrupted during it, debate style.
Monica
That I could get around...
Amen brother
Shut the abc down.. & the project that waleed Ali belongs in a blender
That rita panahi is spot on
  • Like 1
I'm not saying it's a perfect show, but let's be honest, Abbott's not doing this because he wants a balanced ABC...
I gonna have to agree wth Leroy here; it's more of a newspaper now. Going for ratings to stay on air and the formula is get a couple of people from the extremes of an argument so we have no balanced opinion on anything and the audience might as well be given a neon applause and boo sign...shit is worse than jerry springer now and possibly even the WWE.
I hope Abbott doesn't shut it down and I doubt he will, but would like to see a reformatting / reboot...hell even banning the obnoxious "what about me and my Muslim best friend who wants the freedom to make a bomb but would never hurt anybody" minority uni students from the audience would be a great start.
other than realestate.com.au where is good to look for property?
or are you better to go into the local realestate agents?
cracked it and want to get something soon.
Domain and realestate are good apps.
However my house was sold prior to listing so it helps to show agents you are serious so they contact you about new properties.
Must be the first time ever someone has ever made such a comparison
Mae Young should host Q&A. I would actually watch it then.
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
