Perhaps if they weren't blocked at every turn it would be a different story
in fairness, their utes/trucks store their work-gear & tools for the job. They cant be parking 500m down the road & running back/forth for tools etc
Their car is their tool; the location of your car whilst working at your office wont impact you other than arriving/leaving times.
I'll agree on that to a point. But plenty of people use a car to fulfill their work obligations and they don't get special treatment
Nope.
Plenty of jobs have "carry stuff" requirements
Nope.
The utes/trucks may be used as a mobile workstation for welding/cutting/fabrication along with storage of tools.
Yes, people may use cars to fulfil their work obligations, but if it involves anything more than the above then they should also get a permit.
everoyne would expect to see an LS1 under there.
NOTA33 would be more entertaining. wish Tony could sport NOTGTR.
you should let the engine do all the work and get T51 just for the street cred and to have a chance of being photo'd when near a 34GTR
an electrician with a victorian licence cant do electrical work in WA or QLD without going through their hoops and licensing process.
I highly doubt foreign electricians to be granted work visas and to just magically get jobs (legally) when:
a) there is a work shortage with many in the electrical industry looking for work
b) immigration has tightened up like a ducks butt since 2011-2012
c) the companies with the power/cash to do 451 visas would most likely not risk hiring people with questionable skills and knowledge. (especially blue collar workers)
regarding unsafe cabling and installs in houses... home owners agree to it because they dont want to pay the extra for a proper job. someone beats a quote by a few thousand dollars and most people dont think twice about it.
Who do you think you are telling these experts what's what?
Q&A doing its usual close ups of audience hipsters with ironic beards and intense looks of concern on their faces
How much more is my mocha chai latte going to cost if this new tax comes in?
God these rainbow display pictures are annoying, yes I support gay marriage - no I'm not a sheep..
http://www.theatlantic.com/technology/archive/2015/06/were-all-those-rainbow-profile-photos-another-facebook-experiment/397088/
could be a potential facebook book experiment, monitoring how peoples views change based on their friends & how long the change lasts.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
