Gee you're so impartial Ham
Sure am... ain't my fault the incumbent PM is a misogynistic, homophobic, biggoted, xenophobic fundamentalist christian turd sandwich that came to power on the back off another parties f**kup and a bunch of 3 word slogans aimed squarely ay bogan australia....
Let me know when you're done huffing and puffing, so you can acknowledge that it was your ideological compadre Bill Shorten who uttered the above (in the context of being questioned over what a slimy prick he was and is)
  • Like 1
Martin nailed it.
I have 1 teflon pan only and the resf are seasoned cast iron
Industry standard and completely non stick if you look after them
room mate f**ked my good pots and pans up with a scourer, annoyin
Draggin bikes I don't mind when people do that - never know how shit a rider could be at launching, but when cars try to race bikes playing traffic gaps, it's just dumb
I remember when I first got my R1 and outside Knox had a 911 turbo behind me at the lights - was the first time I properly gunned the bike and I scared the shit out of myself. He tried to stay with me and from that moment onwards I declared bikes to be awesome!
Have beaten a few naked 600s in my car off the lights, even a CBR600 was surprised in the traffic when I was running ethanol; asked me how much power I had at the lights. It's not impossible to beat bikes but they do it so effortlessly...really have to try with a car.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
