napster? limewire? or better yet was this being shared around on IRC......
just give him the link to the MP3 you have secreted around somewhere.
send me the link as well.
kazaa? imesh?
IRC downloads through bots, downloading 100x 5mb zip files.
Heart goes out to iMesh
Fantastic porn service with preview option
Ahhh the days of having to trust file names for their content and judging a file mostly by its file size
just so long as it was not the jamster frog..
that was both the worst and best thing we ever did.
I can tell you right now that when it came out Scott Alert (Ric will know) had that ringtone
  • Like 1
that that helped our CEO's christmas bonus.
and what large bonus' they got from it as well
from https://en.wikipedia.org/wiki/Jamba!
In late 2004 under Irvin's direction, VeriSign bought Jamba for $270 million.
Jamba/Jamster boomed—when VeriSign bought the business it had a turnover of $15 million per quarter and 3 quarters later this increased to $150 million a quarter—in 2005 the company made close to $600 million
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
