They need to recoup hecs way faster and cap it at like one degree there after fund it ya self fkn art students.
Waiting to hear about my tax am
Anticipating significant return .. Although paid a ridiculous amount of tax
That doesn't really help the situation for people who can't find jobs...will make it worse if they gotta pay more. Need to pull hecs funding out of industries with an oversupply of candidates, like engineering; a loan scheme should be used to draw prospects towards jobs in need of more candidates and away from the overpopulated areas that result in people being jobless and on welfare with no quick way of paying back the debt.
  • Like 1
Courtesy of my income tax receipt:
Look at all that welfare...families is getting damn close to pensions...like ffs, if you can't properly afford kids don't have!
  • Like 1
Except you can't predict where the industry or demand will be in 3 to 4 years.
Engineers who started their degrees four years ago were in the boom times, when they've finished the boom was over.
I started my engineering degree in hopes of working for Toyota/ford/Holden. Then recession happened in my last year & they all shut down.
  • Like 2
So birds, plsh explain again how Tomich is not a flog and it's all Tennis Australia's fault
Tomic arrested after drunken party in luxury Miami penthouse http://ab.co/1GoVb4P #abcnews
pfffft who hasn't been arrested after a drunken party in a luxury penthouse these days
exactlly.
for me it was Comp Sci and the dot com boom.
I was lucky enough to get a job about 3 months b4 it kicked in, after leaving uni 12 months early.
those that started with me and got their degree, bad luck.
That's a reasonable point but people study endlessly because the can and it's free and get bs degrees and have no thoughts of paying hecs back. There should be at minimum and incentive to pay it back faster ie 10% discount
the numbers of permanent students is tiny, those there for like 10 years are usually getting Phd's and such and will earn it back in the log run.
yes there a few that don't want to work but it's easier to be on the dole with much less work.
as for the discount if it still like when I was paying it back if you make lump sum payments on top of the stuff coming out of your salary then yes there is a discount. used my first couple bonus at work to kill mine off.
oh and it hasn't bee called hecs for years, it HELP now and your all showing your age.
A good point.
You may not be able to predict demand (to a degree you can; what a pun!), but you can certainly count the number of enrolments and be aware of big trends in favoured courses or career paths. I'm not sure how the qualification process goes to decide which course is hecs eligible, but surely a government department has a say in that - yet it's the universities spitting out places and degrees like nobody's business.
It's pretty dumb to let people start a degree during a boom when it's not expected to last - that's a recipe for debt that won't be repaid anytime quickly and another person on centrelink.
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
