sup bitches
Sounds like you've been spotted already
Black R32.
Has been parked out the front of the local cop shop for a long time now. FMIC with DIY "HKS" painted on it, blue front/rear bumpers. Missing drivers side window so I presume stolen.
Anyone missing a black R32?
hahaha the one in mooroolbark.. such a dirty 32
do they have to check your id via anal probe?
did you jsut misplace it or your about to travel and realize you are screwed?
A little from column A, a little from cloumn B.
Lost it when I moved house, travelling in 14 days.
old birth cert that i used TO GET MY LAST PASSPORT not acceptable.
need to get new birth cert.
get all my docs signed by a JP and sent off... paid for express postage
get a letter back (not express post either) stating that it has to be signed by a JP, in a police station. so I have to go to the C.I.B. and have some shitckicker freshfaced cuntstable that probably barely finished highschool sign off on them, because aparently being within the walls of a police station makes him more trustworthy than the official JP that I used that spent close to 10 years in medical school.
go to BDM and they give me my birth certificate and an UNUSED EXPRESS ENVELOPE because i had paid for it and they didn't use it.
go to post office for my "interview" with all the docs and get told they can't do priority apps.
call passport office and get told that all post offices can
get the app done and have to pay $233 + $103 priority processing fee.
put application through without "lost passport" fee as passport is expired
call passport office agaqin just to double check.
as my passport is expired LESS THAN 2 YEARS ago, i need to redo the application with an aditional $103 fee.
go back in to PO.... queue up for a 5th time for the day and get it processed
and it's STILL going to take a week!
Guest
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
