So today was the first day my cars temperature went passed half way and almost at the H marker.
Should i be worried?
Cause its sitting in the garage now making gurgling sounds n shit and ive never had a car that heated up that much.
Yes you should be worried. Stock gauge only hits H when something is very wrong. Check your cooling system.
there has been a bit of this going on for a while already. parts suppliers get ready to close doors, car manufacturers cant complete cars without specific part(s), so they throw enough money at it (making a loss) to keep the production line running until they find a new source for the same/similar parts.
Some of the decline of the Aus car market i think is still due to the slow and pain death of the manufacturing industry, not entirely on price and market domination
Dat awkward feel when your job is in manufacturing industry :/
+ 1
I'm going to say that your radiator is gone
Same thing has happened to me.
+ 1
Careful Steve, Tony's car is now a write off... Learn from his mistakes before it's too late. Check your coolant and make sure that you've got pressure... Could still be something simple like your radiator cap not holding enough pressure.
Lol don't scare him
My car was a write off for different reasons :P
have you checked your coolant?
Im going to guess that you need to top up the coolant in your radiator
It never hit the H, it went to the notch before when i was stopped. Mate told me to check my water pump =\
remove drain plug and turn car on.... if water is pumped out (as opposed to drained by gravity) your water pump should be fine
you'd be surprised how much of an effect a busted rad cap can have.
Lol don't scare him
Car had a minor done last week. It was when the car stopped on the freeway ( trafic ) the heat would rise, but once i started rolling (60 km/h+) the needle would drop. the part that concerned me the most was when i got it home and shut it down the water bubbling sounds it was making.
Suits best show ever waiting or season 3 bad season 2 was epic makes me wanna be a lawyer every chck is smokin! That and they seemingly do no work and make millions.
That's reality right ?
Yeah Harvey Spectre is baws
New episode is out on 17th
Pepper your angus
You're kidding right...just sending the suit back over takes a month or two.
Last time it was about $550 for a full suit + two tailored shirts.
Thats pretty pricy
I'm paying around 400 for mine with 5 shirts, Tailor in HK
last one was from thailand, quality was shit.
but yeah I went from hating suits to loving them jsut from one tailored job.
when something fits perfect you love wearing it,
oh yeah and cufflinks do rock.
mmm carbon cufflinks
The hot part is...last two girls I hooked up with were lawyers, both pretty cute...there was a third that I didn't get with. Saw a hot lawyer in the paper the other day too. Envy for Ric's job!
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
