Are there any major (or minor) differences between the FC Hako and a Datalogit?
From what I understand:
- Hako has 2 analogue inputs; DL has 4 (for wideband O2 sensor etc.)
- DL comes with it's own software
- DL can run hand controller at same time (no idea why you'd need to)
- Hako is $140 cheaper
- Hako will work with all softwares, not just FC edit
Don't need the extra analogue inputs unless you're hardcore into tuning...though you could still do this on the Hako with wideband and EGT sensors. I only wanted something that could load and save maps when switching fuels, so Hako it is.
Steak and BJ day today
I'll probably have chicken for dinner :(
Would it be awkward if your mother cooked steak for your father tonight...awareness not always a good thing.
210kw at the hubs, 19psi, 11.5afr
Exhaust cam retarded 8degrees
Good to be back in the 200kw club
Was tuned last night in the heat and intake is being restricted. (Dat intake pipe)
so you specified hubs because???
Have used both...
Hako is the way.
USB and cheaper. just need someone that has Datalogit and is willing to give up the software ;)
also it is nice to be able to run the HC at the same time so you never have to unplug the shit... just chuck in computer and away you go... other than that, no advantage
Have used both...
Hako is the way.
How difficult is it to save your existing tune to laptop and swap between maps?
Guest
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
