f**k that,
having a break tomorrow...
had to go to a vcat hearing a couple days ago lol.
customer had bought a fridge from us 6 or 7 years ago.
fridge didnt work, issued 3 warranty call outs, in the end we agreed on a refund.
dude rocks up with a munted fridge, claims it fell off the truck but its still our fault that it fell off the truck.
then trys to get the full refund out of me,
in the end i offered him 1300 which he declined, kept it for 2 years and had to scrap it.
then takes me to vcat for $2700
ended up settling on me paying him $850 lol
mate was interested in it if it was cheap enough
she wants $12k with no rwc, no rego, car looks like balls, and a wrecker engine, dreaming
Offer her $50 and a crack pipe then?
As long as the compression is good that would be a decent deal I would have thought
Car looks like shit still compared to when I had it, also going by what her previous car looked like it's no surprises it looks like shit
I like dimple 15 but for the same money I prefer Glenlivet 12
if you want to start, minimum spend on a drinkable whiskey is ~$50
for a beginners scotch @ $50 you can usually get glenlivet 12, glenfiddich 12, dimple 15, balantynes 12, or chivas regal 12 - any of these are very approachable drams
If you are happy to spend the coin I would say the best one to start on would be Glenmorangie 10 year which will run you about $65
best value would be JW black for $38 @ dan's but this is a) not as nice as the above b) much peatier, which is not as beginner friend
Thanks, will probably give the Glenmorangie a try. Best way of drinking it? On the rocks?
Mad they've got more money than most of the people in there...
Incorrect.
They EARN more money than most people in there, then spend it on a maloo, a jetski, a dirt bike, piss and hookers and then leave the mines with nothing to show for their wasted years :P
Guest
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
