yea I often play games through 4g on my work laptop while bored in hotel room
I got 85mbps at shepparton one weekend at the deca hotel
edit: you also missed my D1R que
Edited by UNR33L
Thanks peoples. I dont mind the square, mainly because not many cars can pull it off. I would prefer a more sharp square or is it too merican v8?
http://i00.i.aliimg.com/wsphoto/v0/1586797766/2-4-font-b-Inlet-b-font-Rectangle-Shaped-Dual-Outlets-font-b-Exhaust-b-font.jpg
http://solo-performance.com/images/tips/t109-1l/1.jpeg
Struggling to stay awake, Sandown track day really took it out of me. Still need to unpack the car but cbf.
Evo back home with no issues, how's your rex Grant?
Made it to home by nursing it a bit.
Still need to do few things before heading out again. Platts has talk me into converting to sugar cane fuel, I foresee bad things :P
Lawwdd give me strength I am definitely the same right now, it can all wait until tomorrow!
I would have tried to talk you into it, but you never listen anyway. :P
now do a winton day drive up in the morning, race all day and drive home at night.
then I'll listen to you..
Will do, now I know it will take it. Shakedown ran smoothly, glad it was at Sandown as the tow charge would have been cheaper. :P
Evo is a bit of a handful to drive fast, and will only be faster by the next track outing... Coilovers and more boost to come.
You have stock suspension?
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
