Triple J is good for 2-3 hours one day of the year
The rest of the time it's like a red headed step son - don't wanna hear from it, don't wanna see it, don't wanna know it
106.7 PBS for the win
JJJ is the only other option
Can people honestly, legitimately, stand to listen for more than about eight seconds to any other radio station?
I've tried, and I just can't.
Just unable. Results in actual angry changing of radio stations.
Just drivel.. just like... news.com.au in audio form.
How? Just..
  • Like 1
Where you wanna buy?
Nagambie.
Want some space, like 2 acres min.
Keeps me within an hour of airport, which is better than half you eastern suburb folks! and close to our families for when kids happen.
Been too cautious I think re a house esp when looking to borrow prob 200K -250K to start with, Obviously that will go up in a year or 2 when found a house design happy with.
I love how the kunts that listen to triple j can't bring themselves to admit that even they don't like half of the shit played on there...
THIS^
You hop in a triple j kents car, there could be complete SHIT playing but they won't change the station. Ever.
I don't get it do they wait and hope for something decent? too proud to change station?
  • Like 1
How? Just..
I would have thought you'd listen to whatever the tow truck driver had on at the time
  • Like 1
THIS^
They wait for the 1 in 10 good song that allows them to say "that's an old song and so last year" when commercial radio/tv eventually picks it up and their normal friends say they like it, or so that they know every underground song on Australia Day and enter their shitty votes for shitty bands only to lose out to the most commercial song which always gets number one anyway, proving most JJJ listeners are hypocritical douchebag hipsters.
The radio does not actually work in my R34, but I quite literally don't see the point in fixing it..
No, its the case that everything else is worse. It's the best there is, and tbh I don't feel like murdering the DJ's that talk on the radio on JJJ.
I absolutely violently detest ads.
See also on MMM
Collingwood this
Essendon that
sweet jesus f**k I don't care
then some ad
angry change stations
repeat on every station except the ones that play classic music, PBS, or JJJ
Greg pls
JJJ DJs are 30+ year olds trying to sound 18 years old using the stupidest words, music festival this and home grown from some shit town in fk knows where that - insert stupid anecdote/story about a friend's party that goes absolutely nowhere and then the DJ laughs at their own joke wtf
  • Like 1
RRR and PBS.
if they start talking too much or playing depressing music, switch to the other. If all else fails, 105.3 hell even 89.9 if you're really desperate. some politically correct 90's pop doesnt usually go astray when Eddie McGuire is still on air.
THIS...
I hear it as i'm driving to and from the station each day and that's enough.
99% of it is crap, but slightly less offensive to my ears than MMM etc
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
