Any S2000 haters really need to drive one!
My friend bought one about 4 years ago.. told her to sell it after test driving it cause it the thing had no torque what so ever, you really need to rev the mighty 4 pot to get it going.. She bought a brand new Rx8 3 months after her S2000 purchase, a rotary, which is even more worse for torque
*facepalm*
S2k is a drivers car, you are obviously not one
Nothing wrong with having to rev it out, just drop a gear like a motorbike. It sure beat turbo lag in the traffic. The go kart handling is enough to impress me!
It does actually! Better than my R33 with sunroof :(
That's one thing the Euros did better than the Japs in the 90's...sunrooves that slid up onto the roof rather than into it, which creates more headroom.
Paul is referring to the fact that statistically the odds are against you as a p plater. There is a very large chance that you will stack it so why not stack something u don't give two Shits about
because 1 im fed up with older cars
2 i need something comfortable to daily and be able to hold a 6 burner range in the back
3 it has to look half decent
the ford ticks all those boxes, if i cant get the FG ill just settle for the BA
I spent 25k when i was 19 and 15 months later another 35k on a second car never had any problem just wasn't a dipshit driver - 0 accidents
Moh if it's for work then you'd be eligible for tax deductions of assume ? Tony could tell you better Though
Guest
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
