Age Excess?
Pat, you still under 25?
And fuck that vehicle Excess, so shit!
only 23. Couple more years to go!
Revzone +1
They my main workshop. Do a great job although a bit more pricey, their service and delivery you can't fault. They have a hub dyno though
Telemarketer: Hello can I speak to the business owner
Me: Speaking...
Telemarketer: Hello sir I am from Telstra, the reason I am calling is because I want to save you money on your monthly phone account
Me: I don't have a phone
Telemarketer: *silence*
Telemarketer: How am I speaking with you right now?
Me: GET OUT OF MY HEAD
Bahaha awesome.
you can get spare parts from taxi wreckers
so this is no surprise!
hahaha
Haha, was eyeing off the throttle body setup when I was there getting tyres @inverse on Saturday. So want itb's on a 20 haha
can only be done with a custom made manifold piece to the itb's iirc? lots of work/$$$ etc
Bit of rust in the beaver panel.
Should I cut it out and fill it with brass.
umm no one fills with brass man
there's nothing you can do to it that wont make it look like a typical try hard bogan mobile
so just leave it stock and clean
Aaaah yes, the dreaded falcadore bogan potential. Never thought about that issue tbh.
hahaha
Pretty sure some peeps fill with it.
Either way searched and looked dodge.
Need to find out what thickness steel, got a metal bender and shit at work. Can't be that hard to Make some steel to fit.
lebo...
haha that's for sure :P
yeah full dodge, like doing any filler to cover rust
just have a panel made or get a wrecker to cut one of a wrecked car and weld back in (this is just more effort than new panel though)
Alex did you go to the JDM meet last week?
Heard over 200 cars? True or exaggeration?
Close. possible. they opened up the bit where the wharehouse is for more cars
Pic. more cars on the left behind the truck too. and all along the driveway
Guest
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
