So which option give you 40 million?!
for final heist? dunno - i ended up using the people that cost the most for 100% sure completion (instead of losing shit like i did in the first heist by cheaping out), and doing the sneaky approach. ended up with ~20mil per character, plenty enough for what i need. i do like the idea though of doing a replay but not doing any of the assassination missions until after the main story if possible - can then spend massive dollars on investments instead of like 100k.
ah wait here we go
  • Hotel Assassination: Invest in BettaPharmaceuticals (BAWSAQ) before the mission. Look for a 40-50% return.
  • Multi-target Assassination: Invest in Debonaire (LCN) before the mission. Look for a 80-90% return. Immediately invest in Redwood (LCN) after selling your Debonaire stock as Redwood will see a 300% increase within days.
  • Vice Assassination: Invest in Fruit (BAWSAQ) before the mission. Look for a 50-60% return.
  • Bus Assassination: Invest in Vapid (BAWSAQ) after the mission. Ignore any graphs or green/red arrows, if the stock value is well below the "low" value, invest. Look for a 80-90% return (I had to die once before there was any change to the stock).
  • Construction Assassination: Invest in GoldCoast (LCN) before the mission. Look for a 80-90% return.
the fifth one on that other list is a random event as you drive up the west coast - dude wants you to get him to the airport and gives you a tip when you drop him off; 30% return on it.
BAWSAQ is the online one but certain stocks affected by in game actions (a la Lester's missions) are affected as such temporarily.
Sped through the main missions on my second run. Finished yesterday.
Did all of Lester's assassinations this evening. Had about 32mil on each character after final heist. Played the stocks as people have said: cpd put up the most concise guide so follow that.
Made Franklin a billionaire (he's my main guy, he owns all the properties), got a bit Lazy with Michael, only did the pre-mission investments for immediate cash in, more than enough for all his cinemas.
and couldn't give a flying f**k about Trevor.
Yeah, I had heaps of trouble at first with Trevor - too much of a psycho, and how he treats people. Had to skip all his cutscenes.
He seems to mellow out to just being weird by the end though, so it was easier to watch.
Gonna have to run through again; can't wait for PC and 1440p and mouse aiming though! Stupid thumbstick. Would give up auto-aim for mouse any day.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
