I must give a hat-tip to whoever did the aftermarket parts for the game.
(My dorifuto Futo)
I love the shakotan exhaust, the subway ring hanging off the bumper in true bozo fashion.
Found a few nods to the automotive scene in the game.
The set of wheels that look like SSR SP1's are called 'Ruff Welds'.
Ruff Weld -> Rough World -> Rauh Welt Begriff Reference?
Most of the wheels look like existing wheels, Te37v's (above), ce28's, Regamasters (which have 'master' in the in-game name)
And the Elegy RH8 (GTA's GTR clone): i like to think is a reference to Record Holder 9 [RH-9]. A title given to select GTR's across the world that are road registered and able to run a 9 second pass (on street legal tyres, with 4wd engaged and with no parachute or wheelie bar) amongst a few other guidelines.
no idea, you're not like in a mission or something. do random encounters hide the mission icons?
maybe try killing yourself and see if it resets.
It's like that for all characters though(?), might be a glitch
EDIT: quick google, this came up
GTA V – Can’t Trigger the Last Part of the Merryweather Heist
In the Merryweather Heist mission, you may not trigger the final part of the Port of LS Heist. This part may be lock; you must complete other missions as other characters such as The Long Stretch, Hood Safari, and the third FIB mission.
To complete the third FIB mission, you need to receive a phone call while playing as Trevor or Michael. Switch to those characters and make sure your in-game phone is on.
Edited by alex182
Btw I got a trick to buy properties for free
Purchase the property and straight after confirming that you wish to purchase then pause the game and go to the game menu.
Select to re-play one of the previous quick missions such as saving your son on the yaht.
Once you finish the mission it will take you back to your game with the property purchased and all the money still in your bank
Found out you don't have to finish the quick mission, just fail it and exit.
Edited by HR31_RB20DET
Anyone one done the stranger mission as Michael where you see a guy at a dodgy little stand who gives Michael a hit of something then you shoot a bunch of aliens? That shit is trippy haha
I'm getting close to the end I think. Is there much that goes on after you do the final mission? I'm hoping there is still a few things to do
You have similar encounters with Trevor and Franklin. Trevor's is equally trippy, Franklin's is hilarious.
I got my nerd on for a few hours tonight. I was sick of not to see all the stock market listings on 1 screen on the website, so i made a google chrome extension
you can download it here http://www.blott.com.au/assets/gta/gta5.zip
you'll need to Google how to add it to your browser as i'm not going to put it in Google Play. It appears to work for me, id like to know if it works for others. It loads in the datafiles from the website, there is so much data in these files, i can do heaps more functions if it works properly.
dude you're a champ!
but graaah at LCN stocks - bought a ton of GOPostal due to watching it go up and down, now it's flatlined low - will watch for a while. i'm an idiot.
edit:;
https://www.dropbox.com/s/azv4or905ochmcm/gta5.crx
crx'd up for people - open about:extensions and then drag/drop into there.
lost all my money in stocks (stupid chart doesn't update, but still affected online) and don't have any properties....
didnt realise you could just put the money in te bank and be safe. fuark
I hate how the game doesn't really tell you what to do for a certain mission. I been driving around completing all these side missions to find that I just hadn't found a getaway car and called the team.
Only reason I discovered that was because I went back through my text messages. So annoying that you can't go into the menu and see what you have to do to start the mission.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
