it's on BAWSAQ:
http://socialclub.rockstargames.com/games/gtav/bawsaq#17
Currently $10.70, I bought when it was $3 or so. Put 400k into it...
Was 10.60 this morning so I put > $1 mil into it. will see how that pans out, but I've got a save so if it f**ks up I'm safe :P
heh, i bought up big in hawk and little, 30% was nice. will keep an eye on that one.
ian, maybe replacement parts? http://www.ozmodchips.com/ps3-parts-c-11_66.html
I took it apart last night but not sure if i want to try and rip open the blue ray. it is one of these ones
http://www.ebay.com/itm/Blu-Ray-Drive-PS3-CECHA-CECHB-CECHE-CECHEC-60GB-20GB-80GB-KEM-400A-KES-400AAA-/151020477925
and it looks like you nead to bend shit to open it
i know a dude that might have a spare one, otherwise ill get a new one off ebay
stock prices are just waves and troughs, but people are testing to see what happens when everyone buys into Hawk&Little. People seem to think it will keep going up, everyone sells, it crashes, rinse repeat.
wish I could stay at home and represent the crew. will be online tonight no doubt (thats if not too laggy)
nuy second hand 360 and game for super cheap, wait until ps4 comes out?
i might give it an hour about 830pm melbs time....
yeah, apparently might not be a bad idea - others are suggesting buy up in it before the japan release (oct 10).
ahhhh, yeah bending stuff might not be good. i could always ask the guys i know at sony, but i doubt they'd have stock lying around :/
also i've got two first-gen xbox 360's downstairs... no case, no hdd no power etc but can probably be fixed, i think they'd rrod' in the past. spose i should do something with them at some stage
its litterally a 5 dollar fix... good little things to have to wire up non smart tv's in the house for media center/ streaming.
true - if anyone wants them they can have them for free - i've got too many devices as it is (ps3 slim, xbox 360 slim, ps4 on the way, gaming pc all on my 27" dell monitor - 40" tv with boxee box and sony internet player). missus would kill me for another thing that makes noise.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
