My friend purchased his twin turbo 300zx, and his 3L V6 twin turbo engine instantly made me jealous.
I've done a bit of research and it looks like the VG30DETT will stack up to an RB26DETT except the RB will rev higher and the VG will provide more torque. Please correct me if I'm wrong.
So I'm looking at purchasing a GTS4 and doing a sleeper build... The VG recently came back up in my research and it's really got my imagination going...
Before I get too enthusiastic and put heaps of money down on it, can someone tell me if this thing will be able to be road-registered?
I was going to pull a dodgy, get the GTS4 registered in QLD and do the conversion after, that way I don't have to get it checked, but the police will want to check under the bonnet and even the car illiterate guys will be able to tell something is seriously different.
Anyway, vg30dett powered awd r32, thoughts?
Also, do you think an RB26/30TT would be better than a VG30DETT?
https://www.sau.com.au/forums/topic/382709-vg30dett-r32-gts4/
See I'm not doing it myself, I was going to get Unigroup or something to do it for me... my knowledge isn't that vast :\
I was slightly concerned about the engine bay... bit worried about hte heat in there as well.
Also, you're saying I'll have problems keep AWD? How's that?
I thought the VG30 would bolt onto a 32 GTR gearbox with a bit of fabrication... but like i said, I haven't got heaps of knowledge.
the awd setup runs a diff in the sump
Not wanting to sound totally oblivious, but the way I understand it is a the sump is where all your unwanted oil and shit goes...
What do you mean there's a diff inside the sump? Is it actually swimming in the liquid or is there a diff where the sump goes.
The AWD sump is going to be the real stopper. If you want to keep AWD you are going to have to seriously re-design the sump. I'm pretty sure there are no AWD VG30's and I doubt you will be able to adapt your RB20 AWD sump onto the VG. I think it would be much much less expensive to buy a 300ZX, I doubt anyone will be able to do it for less than $10 000-$15000.
There is a housing on the side of the sump that houses the front differential. Also, the drive shaft to the LH wheel goes through the sump (through a tube through the sump).
A RB20 sump won't even come close, because it is 6 cylinders long, while the VG30 is only 3 cylinders long!
I expect you will need a custom bell housing to allow the RB gearbox to bolt to the VG block.
LOL at engine out for oil change.
Also, don't bother putting a 26 in gts4, easier to buy a GTR.
But buy a gtst and dump VG30 in, less headf**k than trying to make it 4wd if you want to be different.
you realize every time you want to do an oil change on a VG you gotta take the engine out
sounds like an absolute head f**k when you can just put a 26 in with much easier gains
:\ you're joking right?
Thanks heaps man... Exactly the info I needed to read to get my head around it :)
I don't really want to put the 26 in the GTS4, I was just wondering how the VG stacked against the RB.
I can get the gts4 for around 3k with a f**ked p/s rack and a blown engine, so I thought I might as well buy it (because everything else seemed fine) and engine swap for something different.
VG seems like way too much trouble... might stop the search for now, sell the 33 and use the money to purchase a GTR.
A smarter choice would be the VQ25det or VQ35de. Both came with awd from the factory.
the diff is on the wrong side though
Why VG30 I still dont know...you could build a VERY angry RB34DET for less that it would cost to have a stock VG30 thrown in the car
The car was going to cost $3k, the engine was around $1500, and I bargained 4k to put the thing in. Wouldn't have been too expensive.
RB34DET would be interesting... never heard of that before though :\
Bored out rb30?
In this case, buy it, take the front end out - the whole she-bang. Put GTST K-frame blah blah blah and put in VG30 + box, modifiy the tailshaft to suit.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
