Manufacturers come and go when it pleases them, there are only a few teams in pitlane which can be considered to be actual long term investors in the sport.
As far as I'm concerned the sport was better when it was primary privateer driven with manufacturer engine supply.
  • Replies 5.5k
Posted Images
Maldonardo is the kind of driver you'd be looking for. He's got pace and isn't afraid to pass. Much easier to coach him to stay calm and patient when needed than to try and turn a nice safe steady driver into a fast one.
I think its overly simplistic to say they all worked out the tyres at the same time. Look at McLaren, they are still struggling after a good start to the season and cant find the consistency they need.
Mclaren have been on the podium twice in a row now.
Not saying there isnt a chance you are right about the tyres....but I just dont see it. Go back and consider the nature of the race weekends and the compounds used for the weekends where majority struggled vs good weekends and you will see the compounds are not the same
Well, the Soft tyre has been used in every GP except Malasia (Rd2). And the compounds in the last 2 races have been Medium and Soft - the same compounds used the last time we saw the terrible deg and falling off the cliff at Valencia in 27degree ambient and 45C track temps. The last round at Hungary using those same compounds was 33 ambient and 45C track temp. No-one fell off the cliff.
In Valencia randoms such as Schumacher finished on the podium, both Force Indias and Mercs made the top 10. That's tyre induced randomness.
In Hungary it was basically all the top teams in the top 10 - both Red Bulls, both McLarens, both Lotii, both Ferraris. The randomness and falling off a cliff is gone.
If there's a better explanation for that sudden change after Valancia, I'm all ears.
Edited by hrd-hr30
Just bland and uninteresting
I think their terminology would be "modern and spacious state of the art facilities".
First layer has been completed according to their website. I wonder how many layers are required and how long each layer takes.
http://circuitoftheamericas.com/
Edited by iamhe77
first layer takes the longest. how long the rest takes depends on how much machinery they have and how long they have to wait between loads of bitumen/ashphalt. but i'd think that it'd only take a few days per layer.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
