I think most people are using gtx63s' because one can just machine the housing profile. comp ID/OD 47.1/63.4 mm
With the gt60 the comp ID/OD is 47.2/60.1 mm
The gtx60 comp ID/OD is 45.7/60 mm so an insert sleeve needs to be fitted to the housing to reduce the inlet diameter to suit the comp wheel which is what I have done. Would cost someone a bit to get this done.
The HKS 2530, 2510 and GT2860-5 housings are identical size wise.
I did not want any more power just better delivery.
Plus I like machining stuff.
Garrett require 0.28mm (11/1000") clearance housing to wheel so the clearance will be slightly excessive using a 63 with GT or HKS comp housings.
Which might be a good thing anyway with that wheel.
I also have 2 x gtx2863 CHRAs brand new and 2 x Skyline compressor housings for GTX2863 also brand new. Both of which I purchased from ATP in the States as I was originally going to fit them but have now gone with GTX2860/skyline housings. I may sell them if anyone is interested.
Okay from what you're saying, I can't whack my HKS2530 front housings on a GTX2860 core, and I can't even grind them to fit because they are actually too big? (So I'd need to sleeve them?)
I have my my factory housings, are they usable?
  • 1 month later...
For a GTR, the only solution is to use the factory housings and machine the GTX cores into them. Works quite well.
Speak to Tao at Hypergear, I think he did a pair recently so should have all the tooling required.
domo
I guess you could use the OEM comp hsg so sleeving is not required, In my humble opinion this would be a compromise so I just used some old HKS2530 hsgs which are T04B style (aka 5s) with an AR of 0.6
The OEM hsg. A/R is 0.42 and although from what I have read the A/R on the comp. side does not affect things too much unlike the hot side A/R which has a major affect on spool.
Using the OEM comp hsg might make it boost slighty earlier possibly hotter also. Just what I have read.
Anyway I prefer the HKS 2530/2510 gt2860r-5 housings of 0.6 A/R.
I just turned up 2 x 6061 aluminium alloy sleeves 60.00mm OD 42mm ID x 48mm long. Bored out housing to 59.94mm . heated the housing up with heat gun (measuring it to make sure its bigger than 60.00mm) , cooled the sleeves down in freezer then dropped sleeves in the housings. Once cooled machine the profile to suit . Interference fit is permanent like welding but no distortion. I put 2 scotch keys in as well although that was overkill but thats me. The important thing is the 0.06mm interference!. Best not to press it in cold either as it may gall.
Hope this helps some people out wanting to use GTX2860r CHRAs' with Skyline housings.
Keeping my fingers crossed they will be better than my 5s in every way.
Edited by Meathead
Watched that Motive Garage youtube clip where they put the -5 into a -7 housing.
Works well, has me wondering why GCG have not put a gtx in one yet.
A few guys on this thread have done it with -5 housings and GTX2863 chras, no wot surge...could hear the odd bit but GTX2860 should be safe imo.
I watched all of those clips from Motive Garage and really liked the Getrag in the 32 keeping the 4.1s hmmmm, definitely will look into that one for the my 33. Already has the OS gearset but what the hell.
Looks good Mike, they will work much better than the old melted down coke can cast compressor wheels. Should have incorporated surge slots into the sleeve. :P
Hey Scotty, the thought crossed my mind but I'm hoping it will not surge heh heh
Cheers!
thought you may be interested in this as it seems to come with everything done already (although cant justify the price nor postage silly yankees)
http://www.ebay.com.au/itm/Garrett-GTX2860R-400HP-Upgrade-Turbo-for-Nissan-Skyline-RB26DETT-R32-R33-R34-/250813255556
but if you are just purchasing the GTX CHRA cartridge then machining the front comp housing to fit will work IMO
Queried that one about 5 months ago to ask if the picture was representative
of the product. They never replied.
Looks like a GT2860 to me with cast wheel.
Bit of a con imo
You can buy gtx63 gtx67 proper machined skyline hsgs from ATP online.
Bit of a con imo
could be right. very hard to trust any on-line listings these days
I would prefer buying the GTX cartridge from Sonic Peformance and go from there
I bought mine from TM Sports and Racing in Spain (biggest Garrett dealer there) and shipped to Japan very cheaply and quickly.
To give you an idea of prices in $A gtx2860 chra TMsports $1060 Sonic $ 1540 ATP $1468 GCG-Japan $2000 GCG-Aus $1780.
http://www.turbosbytm.com/chra-gtx2860r
Edited by Meathead
  • Like 1
Is there anybody offering Turbos with GTX Wheels that bolt onto the factory RB26dett manifolds and dumps, I take it Garrett doesn't offer anything like this?
Thanks
Just noticed ATP turbo has the RB comp housing as an option on many of their turbos, including larger options like the GTX3071.
Link to GTX2863R as an example:
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=GRT-TBO-186&Category_Code=GTX
  • 4 weeks later...
Are there any more developments of getting the GTX2860R onto the RB26 with the factory style front and rear housings?
Looks like it is right in the middle of the -9 and -5
I would love to stick this on my car but the whole intake side of things is a pain in the ass.
Anyone running GTX2867's on a 3L yet?
I want to :(
Won't fit though. The size of the compressor map and garretts recommendation says it should be ok on a mild 3L build. Would be curious to see how it goes
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
