  • Replies 231
I was neck and neck with an R35 GTR down the main straight of EC when I only had 320rwkw and im sure his wasnt standard.
So do we think that a properly set up 370rwkw+ 32 gtr would smoke an R35 from a rolling start at 60kph?
So too a standing start if the bloke in the 32 could drive?
I've often thought about this and I've come up with YES
and YES depending if the 35 uses launch control, which I don't think would happen much on the street
the R35 from the factory has proper launch control (full boost before you even start moving) not to mention the larger displacement and much newer tech but it does have a lot of KG on the 32.
without actually doing the test you cant say for sure though.
well what does a 35 run down the quater stock standard? somethin like mid 11's...alot of this good quater mile time can be put down to the launch control
have seen a few 35 run at WSID and they have been high 11's without using the launch by the sound and look of it...
an R32 with 370rwkw+ is potentially a 10 second car
yes i know there are other factors but im talking about a perfect world here
Theres a few clips on Youtube.
Well this in a roll on from 2nd. 600hp R35 v 700hp R34 GTR
So this has gone from a 10 sec RWD R33 GTS-t, to people that don't understand ATTESA.
Now it's onto R35s that have DSG. :laugh:
Surely this is ready for the Wasteland now?
It is.
Quality thread so far...
Yea well this thread got high jacked ages ago so im gettin in on it
just finnished watchin some other clips on youtube as well, havent seen this one yet
Well the DSG (cough...auto) does give quite a big advantage on the strip, also the R35 GTR has more gears so can make better use of its torque curve. It's almost like a continuously variable transmission.
To sum up, a 10 Rb25 is not all about having the power. Its the potential to get it down on the ground, from the get go. You need the launch, you need the traction, you need the quick smooth gear changes etc. You really cannot compare an R35 to any other manual skyline. Unless you're chuck norris, you can't out shift a DSG. Hell even chuck norris cant do it.
Power to weight will always win in my book
In a quarter mile track awd means nothing.
Most efi comes with launch control
Mine is set to 6.5
Mine was jumping to the left
Lowered the pressure on the right tire and helped alot.
So suspension and tires are destructive counter measures against awd cars.
I sure fear no awd car out there.
They are top prey in my food chain. ;)
So u drive around the street with less tyre pressure in your rear right tyre?
Or do u just jump out and lower it when ur at the lights after pulling up next to a GTR
This thread has come a long way from the first page, maybe he didn't read the OP where it was talking about street tires and full weight.
None the less it is a true statement. Ive seen some videos of VL's and rotors make some pretty quick passes with street tyres. The VL is a fat sloppy car while the rotors are generally fitted into a chassis which weights easily under a ton.
Fat as in they can in no way be compared to skylines in terms of their suspension work. My cousin has a VL which ran 12's or 11's and it had almost no suspension work. Fat as in when you smack the brake it rocks like a boat and handles like a boat. Skylines might be big and heavy but they really do not handle like boats. They are 1250Kg, 100kg lighter than my GTST.
Edited by SargeRX8
I think that's why they are good for drags straight out of the box though, the soft wallowing suspension aids in the rear squatting and the front lifting, whereas the Skylines with there sporty suspension is a bit to firm for hooking up.
Although the VL does handle a bit more like the Queen Mary when going around corners.
I think, LOL.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
    • Yep four point harness. Mounted to a bolted in brace running behind the seats. Dont use it for daily driving tbh but good to have for when its needed plus it looks cool.
    • I had to double check the thread title r34 gtt offset advice lol. Thought maybe i posted on the wrong thread. 😂
