E85/eflex And Oil Choice
SS8_Gohan
Hey Paul, if by oil analysis you mean take a test tube to someone for scientific analysis then probably not. I wouldn't know the first thing about that
If you mean visuals of water contamination + photos, of course! :P
Plus, I'm not sure how relevant my analysis would be to you, I only own a lowly gtst, not a full house 2.8 GTR! :P
Ethanol and fuel is same same. It gives no fark for car type or capacity haha.
I made the change to E85 a few months back. I have been using the Penrite sin range for years.
After going to E85 I put some fresh Penrite sin 20/50 in and dropped it today after maybe 3000km.
Oil looked fine. My car is making 270rwkw and has nearly 200k on the clock. It gets looked after but does get a boot full every now and then. To be honest I can't fault the Penrite stuff. I have tried RP and the Motul oils and my car just doesn't seen to like it as much as the Penrite. My 2cents anyway.
i run pentrite with E85 as does everyone i know when they are running E85. Seems to be the oil of choice and doesnt seem to break down as quick as some of the others under these conditions..
if you do some searching on the net you will find that ALOT of people say the same thing so thats a winner IMO
Ok so dropped out the Edge 10w60 over the weekend. Here's my super scientific analysis: It was fine. It looked and smelled like any other oil I've changed before.
I copied the technique I read in Performance Imports magazine by stirring up the oil to see if there was water separated from the oil that would show up as white stuff where you stir it, but I saw nothing.
Note: this is a 270kw r33 gtst that is driven every day, South East QLD weather, lots of extra urban trips when cold < 5 mins driving.
Pics:
20w50 is too thick for dailying an SR20 with just a squirt here and there...
honestly i'd look at something a little thinner, especially on the cold viscosity... penrite have a 10w50 syn dont they?
Edge 10w60 is probably the most one common used in vic
Well it looked pretty good to me? How can you tell if it's broken down?
I would have thought with the type of conditions I operate my car in, it would have gone bad if it was ever going to.
I drive plenty of short trips with a cold engine, where fuel can apparently wash past the rings and into the oil etc and break it down. I do no highway kms, all around town driving. Stop start.
heaps of people use it however I havent ith e85, only 98... personally I prefer motul 6100 15w50 with e85 so I can't really comment personally...
So with all the talk of E85 and oil compatability is anyone paying attention to the oils performance on the turbos at the boost people are running with E85? Seems more important for the EVO crowd who generally, like me are running bush bearing turbos
    • I'll chime in here with my experience. Motec is great if you have the money and know a good person to support you. They don't really offer retail support and the dealers make SFA margin on the product, so the business model is setup for you to be supported by a dealer. I'm lucky enough to know a guy who's ex Motec and very generous with his time and is a total boffin. In addition to that, I also use Brad Sherriff who's an absolute legend to work with. The downside to Motec is the software isn't very intuitive, pay to play, poor/limited online support and costly upgrades.  I've not owned an Emtron myself but a good friend runs a performance workshop in Melbourne who is an Emtron dealer. They won't be fitting any more to customer cars because of the poor level of knowledge within the Emtron support team and lack of ability to solve issues with the platform. Not to mention the circumstances around the establishment of the product and company in the first place. I've run Motec's since the old M8's back in the early 2000's so I'm certainly not without a bias but I look at it like this. Everyone acknowledges Motec as the best consumer grade product without spending mega dollars on Bosch Motorsport / Life Racing and so on. When you consider the real cost of your car (not what you tell your mrs) the cost difference between an Emtron and a Motec is tiny, why would you compromise over a few hundred dollars?
    • Closer to getting the shit box back on the road. That long hose, took 2 months to acquire. However the rest were all already to go same week I ordered them. For those playing at home, that long hose is for a RB25DE N/A motor, as they don't run a water/oil heat exchanger, the hoses underneath the plenum are much more elegant and not a maze of shit.
    • One thing you may be able to leverage is the fact that the R34 N/A has the same setup as a S15. The S15 also is a car that gets 350Z diff swapped, so they will also likely have this problem. The caveat of course is it's possible the dash is different between the R34 NA and the S15, but the subframe/sensors/axles/diff setup are the same. I can't remember now as it's been too long, but I don't generally think people need to swap dashes between the N/A dash and the turbo dash when they do things like change the gearbox out, turbo their car, manual swap it, it's just not something I've seen mentioned so this could be compatible.
