this is weird.... this listing looks like a joke, given the price and the description "built #1", everything just says bogus but the seller has a similar name to the SAU user who actually owns the car??? maybe someone got into his ebay account.
still going to be bogus either way
weird..
USD1m? I'm as big a Nissan fanboy as the next guy, but fake or not, I'd NEVER spend that much on a Z-tune.
there were a Ferrari Enzo for sale some time back via Shanon's for 700K - 800K i think
1M is insane amount of Money for a Nissan, unless done as Joke or to gage interest
around the $200k sounds in the ball park based on ones that have gone in Japan, Australia etc.
GTRSean: as i said, the username seems like the real owner, but i don't get why you would put up a bogus listing like that? Unless it was like someone i knew who got in trouble with the missus and told "just sell it!" so they put a not so expensive car on carsales for huge $$ and then claim "i'm trying, but no one is interested honey!"
still doesn't make sense to me... some sort of in-joke?
/\/\/\ this if you look at his other listing (Porsche 911)
He's put a bit of a description
So I'd say he doesn't really want to sell it and just giving the impression that he is trying to sell it
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
