Regardless of any of it, Nathan is one of the few people that would actually cone here and give what was sometimes good advice to people trying to learn ..thats more than I could say for many of the "look what I bought" builders that come here with opinions and little else..
These are the people that annoy me. Never touched a spanner, laptop, or wideband, but all of a sudden know everything because their tuner \ mechanic talked a bit of shit into their ears to get their money.
I've made mistakes, been mis informed etc, but I try and better my ways as much as possible.
I've been tuning for years, and looking at tunes from some of the best workshops around I have been disappointed and I'm very glad that I can do it all myself and get a better effort, every time, for free.
Edited by The Mafia
Its a good thread and had been interesting to see others running 300+ for quite a while without a hassle....... I plan to join it soon
i assume cams doesnt count as opening the engine? Or does it?
cams are fine.
it's essentially a bolt on part. the point here is more the bottom end
Sweet, well i should be posting in here around mid month if all goes to plan!
  • 1 month later...
mods: master power t56, 550cc injectors, FFP, top mount ex man, 38 ext gate plumbed back, 3 inch, FMIC,bosch 044, link G4 using the link boost control,
fuel: BP 98
power: 300rwkw 2 years, retune with link g4(removing chipped z32 ecu and z32 afm) to 324rwkw, 300rwkw low boost
useage: road use, not daily driven
lifespan: 2 years
failure:
comments: need new coils, still making more power over 7500rpm but limited to 7500, did make 347rwkw on 19psi but pulled it back to 324, can make more power with new coils, more revs,better fuel and more money! :domokun:
oh hai guys, can i play.....303kw @ 17.5psi...
stock standard rb25, stock airbox, stock cam gears, stock manifolds..
see here...
http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/page__st__3820
Just in ;)
see here...
Just in ;)
That's a nice looking graph, is it an external gate?
Yeah, tial 44mm hanging of the turbine housing..
2 E85 outlets walking distance from my house now Alan, I feel so spoilt and the fuel feels great, the torque is like driving my little diesel Ute around, so much low down grunt..As an added bonus I just found out my adaptronic has switchable tunes. Its as simple as flicking a switch to change back to pulp..
lol @ knocking on rattles door, that was a good line.
wish sydney would hurry up and roll out the E85 too :(
Get a 200L drum and store it at your place? I have done that just because the nearest servo is 20mins away?
Not that i have a car finished yet so i can post in this thread like i promised a month ago :(
Mods: s1r33 3076r, external gate, poncams, 550's, uprated valvesprings.
Fuel: Bp 98
power: 307rwkw @ 20psi
useage: daily and track drifter
lifespan: 10 months at this level, 3 years with 270+
Failure: cracked ring no4 cyl, still drove fine just had a weird note from the exhaust
comments: had 270 for 2 years before failing after 10 months with 307, was about to upgrade to e85 but now will wait till I've rebuilt the engine
Fuel: Bp 98
How many K's on the engine, what ECU, who tuned? (maybe relevant to the thread ;) )
let's leave who tuned them out of it as per sau guidelines.
a 300rwkw engine will let go eventually, especially with track usage and it's not fair to the tuners to be receiving bad press because of this.
old motors, over double the standard power, revving past redline :ninja:
Yeah sorry, bad question.... I wouldnt have been blaming anyone for a failure for the exact reason WMDC35 mentions..... Ill stay quiet now until i have a Dyno sheet of my own so i can join this thread properly :rolleyes:
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
