Regardless of any of it, Nathan is one of the few people that would actually cone here and give what was sometimes good advice to people trying to learn ..thats more than I could say for many of the "look what I bought" builders that come here with opinions and little else..
These are the people that annoy me. Never touched a spanner, laptop, or wideband, but all of a sudden know everything because their tuner \ mechanic talked a bit of shit into their ears to get their money.
I've made mistakes, been mis informed etc, but I try and better my ways as much as possible.
I've been tuning for years, and looking at tunes from some of the best workshops around I have been disappointed and I'm very glad that I can do it all myself and get a better effort, every time, for free.
Edited by The Mafia
Its a good thread and had been interesting to see others running 300+ for quite a while without a hassle....... I plan to join it soon
i assume cams doesnt count as opening the engine? Or does it?
cams are fine.
it's essentially a bolt on part. the point here is more the bottom end
Sweet, well i should be posting in here around mid month if all goes to plan!
  • 1 month later...
mods: master power t56, 550cc injectors, FFP, top mount ex man, 38 ext gate plumbed back, 3 inch, FMIC,bosch 044, link G4 using the link boost control,
fuel: BP 98
power: 300rwkw 2 years, retune with link g4(removing chipped z32 ecu and z32 afm) to 324rwkw, 300rwkw low boost
useage: road use, not daily driven
lifespan: 2 years
failure:
comments: need new coils, still making more power over 7500rpm but limited to 7500, did make 347rwkw on 19psi but pulled it back to 324, can make more power with new coils, more revs,better fuel and more money! :domokun:
oh hai guys, can i play.....303kw @ 17.5psi...
stock standard rb25, stock airbox, stock cam gears, stock manifolds..
see here...
http://www.skylinesaustralia.com/forums/topic/347726-kando-dynamics-turbo/page__st__3820
Just in ;)
see here...
Just in ;)
That's a nice looking graph, is it an external gate?
Yeah, tial 44mm hanging of the turbine housing..
2 E85 outlets walking distance from my house now Alan, I feel so spoilt and the fuel feels great, the torque is like driving my little diesel Ute around, so much low down grunt..As an added bonus I just found out my adaptronic has switchable tunes. Its as simple as flicking a switch to change back to pulp..
lol @ knocking on rattles door, that was a good line.
wish sydney would hurry up and roll out the E85 too :(
Get a 200L drum and store it at your place? I have done that just because the nearest servo is 20mins away?
Not that i have a car finished yet so i can post in this thread like i promised a month ago :(
Mods: s1r33 3076r, external gate, poncams, 550's, uprated valvesprings.
Fuel: Bp 98
power: 307rwkw @ 20psi
useage: daily and track drifter
lifespan: 10 months at this level, 3 years with 270+
Failure: cracked ring no4 cyl, still drove fine just had a weird note from the exhaust
comments: had 270 for 2 years before failing after 10 months with 307, was about to upgrade to e85 but now will wait till I've rebuilt the engine
Fuel: Bp 98
How many K's on the engine, what ECU, who tuned? (maybe relevant to the thread ;) )
let's leave who tuned them out of it as per sau guidelines.
a 300rwkw engine will let go eventually, especially with track usage and it's not fair to the tuners to be receiving bad press because of this.
old motors, over double the standard power, revving past redline :ninja:
Yeah sorry, bad question.... I wouldnt have been blaming anyone for a failure for the exact reason WMDC35 mentions..... Ill stay quiet now until i have a Dyno sheet of my own so i can join this thread properly :rolleyes:
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
