if you dont make it then just have the tuner create a good graph and claim it to be your own, thats my plan ;)
No cheating ya goose :P And you'll be fine with your setup
I wanna join :(
Fingers crossed the SS1PU can push me into the 300's with WMI or E70
I'm only just in the club at the moment as I'm on gate pressure :(
Anyone had Err 100 on a HKS EVC before? Seems to happen every time I give it a thrashing so I've switched it off :/
Yes, yes it is. Either that or it's the tune.
There are only two factors really, but im guessing it's a foot problem.
And my figures quoted earlier - that wasn't using the O2 sensor. That was with it disabled and the tune adjusted to suit.
or sensors are broken
if the sensors are f**ked (reading lean) the ecu reverts to the base fuel map, so if that's tuned properly you shouldn't get bad economy from busted sensors. The ecu only uses the o2 sensors to trim fuel on cruise, it'll never add more fuel than the base map.
Unless the sensors are telling the ecu its running lean so it adds fuel.
I have seen it alot. Unplugging the sensors then helps with fuel economy
DVS Tuning helped me
Join this club today .
At this point in time my 34 gtt sedan is making 353kw on eflex but howevet running out of fuel
Tune soon to be 100% completed once fuel system is upgraded again.
What if the coolant temp sensor is broken and constantly tells the ECU it is cold so it runs fuel enrichment and ignition retard? Definitely make a big difference to fuel economy!
Lol 34geeteetee I'm pretty sure err 100 is an open circuit. To test that have the car running at a time the Evc is working fine then unplug the solenoid. If it gives the same error thhen that means open circuit.
it would be doing.that when its hot coz the heat makes it expand and It must have a dry or cracked solder joint inside. Make sure it is far.from.the. exhaust and that the solenoid barbs point directly skyward.
also why.does it Sig say 360kw but u keep saying its in the process and are up to 300 odd? 2nd tune?
Thanks mate... Will hopefully get it sorted before Texi...
360kw was the highest run... It was run @ 357kw on the final tune for safety... The reason for the different power figures is the 3 boost levels and also the % of ethanol.... My power ranges from 311kw to 357kw depending in boost and E content :)
Hope that makes sense?
Duno what it is mate, its pretty f*ked getting 19-20L/100kms, will definitey have that issue addressed in the tune when I do a turbo upgrade/ tune. My new O2 sensor cannot be the prob, I was getting similar economy with the old one, the sensor is working ok because I do get better economy on long drives
In-car video showing the 34 boosting hard on full boost or its not true? Nah man but Im sure we would all love to see
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
