if you dont make it then just have the tuner create a good graph and claim it to be your own, thats my plan ;)
No cheating ya goose :P And you'll be fine with your setup
I wanna join :(
Fingers crossed the SS1PU can push me into the 300's with WMI or E70
I'm only just in the club at the moment as I'm on gate pressure :(
Anyone had Err 100 on a HKS EVC before? Seems to happen every time I give it a thrashing so I've switched it off :/
Yes, yes it is. Either that or it's the tune.
There are only two factors really, but im guessing it's a foot problem.
And my figures quoted earlier - that wasn't using the O2 sensor. That was with it disabled and the tune adjusted to suit.
or sensors are broken
if the sensors are f**ked (reading lean) the ecu reverts to the base fuel map, so if that's tuned properly you shouldn't get bad economy from busted sensors. The ecu only uses the o2 sensors to trim fuel on cruise, it'll never add more fuel than the base map.
Unless the sensors are telling the ecu its running lean so it adds fuel.
I have seen it alot. Unplugging the sensors then helps with fuel economy
DVS Tuning helped me
Join this club today .
At this point in time my 34 gtt sedan is making 353kw on eflex but howevet running out of fuel
Tune soon to be 100% completed once fuel system is upgraded again.
What if the coolant temp sensor is broken and constantly tells the ECU it is cold so it runs fuel enrichment and ignition retard? Definitely make a big difference to fuel economy!
Lol 34geeteetee I'm pretty sure err 100 is an open circuit. To test that have the car running at a time the Evc is working fine then unplug the solenoid. If it gives the same error thhen that means open circuit.
it would be doing.that when its hot coz the heat makes it expand and It must have a dry or cracked solder joint inside. Make sure it is far.from.the. exhaust and that the solenoid barbs point directly skyward.
also why.does it Sig say 360kw but u keep saying its in the process and are up to 300 odd? 2nd tune?
Thanks mate... Will hopefully get it sorted before Texi...
360kw was the highest run... It was run @ 357kw on the final tune for safety... The reason for the different power figures is the 3 boost levels and also the % of ethanol.... My power ranges from 311kw to 357kw depending in boost and E content :)
Hope that makes sense?
Duno what it is mate, its pretty f*ked getting 19-20L/100kms, will definitey have that issue addressed in the tune when I do a turbo upgrade/ tune. My new O2 sensor cannot be the prob, I was getting similar economy with the old one, the sensor is working ok because I do get better economy on long drives
In-car video showing the 34 boosting hard on full boost or its not true? Nah man but Im sure we would all love to see
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
