18" wheels and anywhere between 225 and 245
18x8" +20 on a 235 tyre
18x9" +30 on a 245 tyre all around is what i run on the front and thats flush to guard no rub no scrub no issues (my car sits slightly higher then most due to my driveway).. so you should have little trouble going that all around (check my photos on previous page)
Hi all,
About to get some wheels tomorrow in the size 9,5j et+26 all around for my R34 GTT with nismo S-tune suspension.
Thread has been great help.
Looking to run 245/35/18 front and 255/35/18 rear. You think I can run this without rolling the fenders or any other guard work?
If not...what size tyre should I run
Cheers from Holland :action-smiley-069:
Edited by ThomasGTT
Hey mate. A 9.5 +26 will have a tiny bit of poke from the guards you may want to run a smaller tyre for clearance issues but you could probably get away with a 245.. my old 18x9.5 +22 had guard rub when going up inclines and full lock that was with lowered coilovers and a 235 tyre.. also worth mentioning make sure you wheels will clear your suspension arms on the front.. mine had a tiny gap between wheel and arm
Cheers good luck
Ps i had unmodified guards.. i would recommend rolling them if your car is lowered with that size wheel and offset
  • 3 weeks later...
18x9+25 would sit a little inside on the rears if anything. Perfect flush fit in my opinion is 18x9+30, even on that it'll sit in a little on the rears but nothing substantial
Edit: it would stick a little out than in, myyy bad
Edited by tiddyd
hey guys, i was thinking of going 18x9 +25 all round, was wondering if it would poke outside the guards considering the front on your ones look pretty flush
  • 3 months later...
To revive this thread, this is my R34 gtt with LMGT4's in 18x9+22 front and back.
Wrapped in 235/40/18 re003's all around.
No camber to them, guards are rolled at the front but probably didn't even need to, there's no scrub at all.
Perfect flush fitment front and back.
  • 2 months later...
More clear photos for you mate, yeah i noticed a huge improvment when i swapped..any photos of your new wheels?
Hey Artic, what front bar/kit is that? Lip looks great on it! Wheels look great also, glad to see a reference as i'll be running a similar 18x 9 or 8.5 + 30 all round when i finally get mine.
Edited by RR34GTT
Cheers bud. Its a ztune replica for gtt :)
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
