"steam Pipe" Single Turbo Manifolds On Fleabay....anyone Know Anythging About This Supplier And Their Products?
Some one was saying that the welds ( wernt pretty ) because we had used a tig and not a mig on the last Wg port we did, well from now on we will use a mig as much as possible. here is a few of the ones we have recently finished and because some one had stated they didn't like how the mig welds looked ( which does not actually effect the performance of the manifold ) we took your ideas on board and made the welds look pretty :) The large one is a 50mm port with a 50mm gate, the smaller one with the gate is a 38mm port and a v band gate, and the last one is a 44mm port with no flange.
  • Replies 384
cant wait to order myself one of these! get rid of my chinese leaking POS. didn't know welds were such a big deal specially when u dnt even see half of the manifold anyway or its covered in heat wrap... each 2 there own.
hi,
can you do a low mount option for RB25 with 44mm ext gate opening??
Giday mate, i won't be making low mount setups at this stage but maybe in the near future.
Kam
Mate when I said mig welds were not appealing I said that from one welder to another and from a customers point of view aswell it's not a personnel attack moreso advice for criticism to come .
I personnly think for the price ur manifolds are it is a steal I would go one of these before I went Chinese but I'm making my own so it doesn't bother me either way .
As for the welds on the latest pics they do look a lot neater which is appealing to a lot of ppl and even if not scene u have piece of mind u have a relatively good looking setup
That's my 2c
Gl with it
Hybrid , just wondering if you could post some more photos of the collector/where the piping merges? Just looking for some macro shots inside. Many thanks.
Giday mate,
Ill post up some pix soon of the collectors for you guys
thanks
I've just gone thru this NZ based supplier's website and all I can say is wow! the prices are good. He is even selling manifold/ turbo packages and manifold/ wastegate packages.
What I would like to ask is, do you do GT3076R spec turbos as I only saw the GT3540 which is too big for my street application- R34 aiming for a responsive 280-300rwkw. What brand wastegates are those, hoping not some cheap chinese shit, and how reliable are your turbos- i know its NZ assembled, is there any write-up on them? Cheers Ron
Giday mate,
Thanks for the support.
Our 3540 is aimed for larger power as the rear housing is quiet big. We will be doing some smaller sizes in the near future. Turbo's are high quality and we wouldn't sell it if we didn't know that. the cheaper range we do supply is for people who are on a tighter budget most GT series turbo's we do supply are assembled by us
Our wastegates that we do supply ( we don't manufacture ourself ) but under a very high quality control and are made in Taiwan not china like most cheaper gates that boost creep. we check each item before sold and make sure they are up to standard.
I will be posting up Dyno charts soon of the turbo's / wastegate's being used on our customer's cars.
Thanks Hybrid,
I reckon if you supply smaller turbos identical to 3076/3071 spec with manifold n gate packages at the prices you have, a strong base of dyno charts on customer cars AND solid reliability backing over a long period, then you will have a HUGE following, a big customer base in Australia is almost guaranteed, cheap and solid street spec turbos are in demand, not only in the the Nissan stables but other makes as well. Keep the good work coming. Cheers
Ok guys over the weekend i decided to take the sheets off my old car which i haven't touched in years. It use to have a stainless manifold with a T3/T4 turbo. To give you an idea the turbo was a fine hair line between the covers it was pretty much touching. The pictures bellow are a manifold we put together for a client with a 44mm port , and the turbo size is double what the t3/t4 was this is our GT3540 .70 A/R front and a 1.06 A/R rear, which compared to the old one it was .63,
Nope you can go direct through our site which is now on my signature or PM me and we can go from there.
Thanks
ebay the only way to order these?
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
