I've got them on 9.5s on the rear, and wouldn't call them stretched.
265s would be better for a 10" wheel, but these are cheap and basicaly full life left in them....
If only i hadnt just purchased a house :( Ill just run the RSR and learn to drive haha
Yokie AD08R's. Anyone know anything about them?
I used them on my old green Gts-t. Managed to match my RE55 time on short track in a high powered rwd skyline so they grip like crazy for what they are (a few suspension changes at the same time so that would have helped)... Not a semi by any stretch but you wouldn't lose time a whole lot of time compared (maybe 1.5sec slower)
Hey guys I'm going to be using the ku36 kuhmos as steer tyres on the drifter just wonderig if anyone's had experience with them, I think they are more of a sticky stret tyre than a race compound, I'm restricted to 205/50/15 in size, main reason I wanted stickier tyres on the front is to reduce understeer
Are you looking for a good street tyre, or a semi slick for circuit use. They are a good street tyre.
If you are after a semi slick the 15" rim will limit you, but it also suggests you have a light car. Look into Toyo 888 and Kumho v70a. They will be nice and cheap in those sizes too
Sorry forgot to say what car it is, it's a s13 Silvia , fully stripped and fitted with an rb25 , i can't see it weighing over 1100kg.
It's purely for drifting and I only want them on the front , was hoping that because they are a street semi they might last me longer than a race compound, also there design allows for use in damp conditions.
My main concern is weather I should have stuck to 17's and weather a 235 or 245 would have provide a lot more grip on the front , for the past year I've just been using cheap tyres like durun and sunny 235/45/17 as steer tyres, hoping that a reduction is size will balance out with the quality upgrade of tyre?
Best bang for buck Druncan ?
Haven't bought a set for a while, and last time I did the Federals were definitely the thing to have for the money. But I see Harry's warning that they have changed for the worst since.
I'd probably go Kumho V70A again, they worked well and didn't require me to sell drugs to fund them like yokos or dunlop.
  • 3 months later...
Anyone tried the BFGoodrich g-Force R1?
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+R1
It's not far off a full semi and they are pretty cheap. what do you guys think?
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
