I've got them on 9.5s on the rear, and wouldn't call them stretched.
265s would be better for a 10" wheel, but these are cheap and basicaly full life left in them....
If only i hadnt just purchased a house :( Ill just run the RSR and learn to drive haha
Yokie AD08R's. Anyone know anything about them?
I used them on my old green Gts-t. Managed to match my RE55 time on short track in a high powered rwd skyline so they grip like crazy for what they are (a few suspension changes at the same time so that would have helped)... Not a semi by any stretch but you wouldn't lose time a whole lot of time compared (maybe 1.5sec slower)
Hey guys I'm going to be using the ku36 kuhmos as steer tyres on the drifter just wonderig if anyone's had experience with them, I think they are more of a sticky stret tyre than a race compound, I'm restricted to 205/50/15 in size, main reason I wanted stickier tyres on the front is to reduce understeer
Are you looking for a good street tyre, or a semi slick for circuit use. They are a good street tyre.
If you are after a semi slick the 15" rim will limit you, but it also suggests you have a light car. Look into Toyo 888 and Kumho v70a. They will be nice and cheap in those sizes too
Sorry forgot to say what car it is, it's a s13 Silvia , fully stripped and fitted with an rb25 , i can't see it weighing over 1100kg.
It's purely for drifting and I only want them on the front , was hoping that because they are a street semi they might last me longer than a race compound, also there design allows for use in damp conditions.
My main concern is weather I should have stuck to 17's and weather a 235 or 245 would have provide a lot more grip on the front , for the past year I've just been using cheap tyres like durun and sunny 235/45/17 as steer tyres, hoping that a reduction is size will balance out with the quality upgrade of tyre?
Best bang for buck Druncan ?
Haven't bought a set for a while, and last time I did the Federals were definitely the thing to have for the money. But I see Harry's warning that they have changed for the worst since.
I'd probably go Kumho V70A again, they worked well and didn't require me to sell drugs to fund them like yokos or dunlop.
  • 3 months later...
Anyone tried the BFGoodrich g-Force R1?
http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+R1
It's not far off a full semi and they are pretty cheap. what do you guys think?
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
