Knew the R888 were too 'soft' for our heavy cars :P.
I said something like that earlier in this thread and IIRC an mx5 guy said they were shit on his car too... So i guess they're just shit. Cheap tho.
  • 3 weeks later...
I am looking for a tyre that is good value for money and offers the best performance for the $$$ to have a go at a few track days.
The car it an R34 GTT. 320RWKW. coilovers, 350mm brakes etc.
I would be putting the tyres on a seperate set of rims to be put on to drive to the track, on the track and back home. Would be from Canberra to wakefield which is roughly 100km each way. I have a separate set of rims and tyres for daily driving.
Rims are:
Desmond Regamaster
17x9 + 38
17x8 +35
I was thinking of getting Nitto NT01
255 40 17
225 45 17
Should be able to get a full set of tyres for around $900. What do people think? Are there any better value options out there?
You talking about the soft compound Z221 - the C7?
How are they relative to the A050's?
There are part numbers on the Hankook website for the tyres which may line up.
So in 255/40/17 hard is 1010343, medium is 1012650 and soft is 1011508 apparently.
http://www.hankooktyre.com.au/Product/MotorsportTyreSemiSlick.aspx?pageNum=1&subNum=5&ChildNum=3#Z221
Just curious because I would like something a little harder than an A050 and better than an RE55. Almost everything else appears to be sht.
Rims are:
Desmond Regamaster
17x9 + 38
17x8 +35
255 40 17
225 45 17
NT01's will be fine to drive to and from the track on but I'd probably run a wider front tyre if I were you. See if you can get the 255 to fit on the front, if not a 245.
I learnt the hard way. Bought a pair of bargain secondhand 275 Z214 C51 "Mediums" for the back of the Soarer, only to find they were harder and less grippy than the 245 NT01s I had on there. I had NFI about the Hankook compounds at the time, but "medium" sounded like what I wanted for sprints. Wrong! They'r enot that old and had almost new tread, so at first I thought they might just have been cooked or heat cycled too many times. But a mate who runs C70s told me about the compounds... At least it was only $100 bucks wasted.
I bumped into the Hankook rep up here at a hillclimb and he explained the C70 "softs" as really being medium compound and the C50 "medium" is really a hard compound. C90 for Hillclimbs. C70 for Sprints. C50 if you want to do a 3hr race!
  • 3 months later...
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
