Well that takes care of the load that would have been placed on the inj circuit, but using this to drive a pwm solenoid means that the pump will have to be constantly on using a 12v source?
Yep, plan is to use a relay and a boost switch, pump receives 12 volts whenever the car hits boost and stays on until the manifold returns to or below atmospheric pressure. Same 12volt signal would send power to the solid state relay to activate the solenoid.
So ive been doing a little research on evolutionM forums and it appears the biggest worry is getting even cylinder distribution so a lot of people run multiple jets to feed each cylinder.
Which brings me to a query, I'm running a plazmaman forward facing plenum and was going to just set up a progressive system with the jet ~8-10 cm from the TB.
Do you think this would cause uneven flow with a ffp? I'm a little concerned that cylinders 1-3 will end up getting all the mist and 4-6 will "starve" if that makes sense.
Idealy I should probably have a jet in each runner but room is pretty tight and IMO its creating more potential for failure points with multiple nozzles and tees for the feed lines etc.
Thoughts?????
Also interested in this. Slowly figuring out how to make my kit work the way I want, and this was a concern. The solenoid will be run proportional to a fuel injector, same duty cycle and maximum 60hz frequency. Simply put, the engine will complete two revolutions and fire 6 times, for the WMI to inject a %15 mix once. Will this cause problems (even with the stock intake) with cylinder distribution if the nozzle is the usual 80cm before the TB? Or will the manifold, piping and TB send a roughly even amount to each cylinder as the intake valves open in sequence? I have read GTSBOY's comments, can anyone running a single nozzle system confirm that it's relatively safe?
Edited by blk94r33
havent read all the pages, but what do you guys think is better overall E85 or water meth? I like the idea of water meth so you only use it on a set boost or throttle point over the constant expense of E85.. but what about results like mid and top end power torque wise?
From the results I have seen, wmi looks comparable to e85 for top end but if your injecting progressively based on boost you won't get the off boost increases that e85 gives.
If given the choice out of both I would go e85 without question, but wmi seems like a good solution for non e85 areas.
I'm injecting 320ml per minute atm (50/50 mix) on my stockish stagea (cooler/12psi/exhaust), switches on at 10psi
and i get no bog or hesitation either, i think i will just leave the system like that then and not worry about a progressive controller
as when i put a looser converter in
it it will "flash" past that point anyway..
cheers
darren
Edited by jet_r31
It interesting to see how much water sombre was injecting, thats the most of have heard of for that
power level, be interesting to know if he played with smaller jets to come to that conclusion or just sized up those ones and left it
cheers
darren
Hi Darren, someone brought your post to my attention :) I didn't experiment with smaller nozzles, though I had them available.
I bought my kit as a customised one put together by a US based vendor with a lot of experience using WMI on very high hp cars. He suggested these nozzle sizes, which I initially queried because they were both rather large and the inverse of what the Snow Performance FAQ seemed to recommend (i.e. large primary, small secondary compared to the recommended opposite).
In this vendor's considerable experience with very high hp (and $$) 2JZ motors, he had found that the rate of torque generation, and the corresponding spike in cylinder pressures and heat, mandated higher volumes overall and a large primary with a smaller secondary, to allow the WMI delivery to match cylinder events and maximise the benefits. I have no perceptible aberrant quench now that it's tuned, and the results speak for themselves so I'm satisfied with his reasoning :)
I regard the WMI mixture very much as a consumable for safety. As I'm about to go bigger again on the motor side of things, it's also nice to know that the infrastructure to support the new setup is in place.
HTH.
Edited by shombre
Is your system on straight water or water/meth Darren?
I've just got my aquamist up and running and using their jet calculator I've ended up with about 900cc of maximum flow with my 750cc injectors @ 95% idc. I'm running a 50/50 water meth mix. Obviously it won't be using all that flow as its based off idc. I'm keen to see some good results from it
I dont know if im reading/interpreting what you're saying correctly, but you shouldnt need to be running at 95% IDC to get your wmi nozzle flowing at max capacity. You should be able to fiddle with the settings and say at what IDC % you want it to start injecting the water meth mix and at what IDC % you want it injecting at full capacity. It should then ramp up the flow progressively between the minimum set point to the max set point.
Edited by Mitcho_7
water/meth in stagea, in R31 just straight water
cheers
darren
I can define when it starts injecting and what rate it ramps up with idc. It can flow 900cc's at 20% idc if I want it to. Their recomendation is 15-20% water meth to fuel so obviously at a lower idc its putting less fuel in which means less water/meth is used. Out of the box its set to come on at 44% idc which is 10psi on my set up with a rate of 1:1
What would you like to know about them? You won't get full voltage out of one like a relay but they work well. I have some 40 amp ones here if you want to test a theory. Not sure how fast it will switch though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
