Ahh OK. So you are considering going down the WMI route too? :P
Yeh I'm thinking about it. Need to get my car going properly again first, but it's something I'm thinking about for the future. If E85 doesn't become available/affordable here then I'll probably go with WMI.
Running 315rwkw, I saw no difference between 375ml and 675ml nozzles, only a bottle that emptied twice as fast.
With the 375ml nozzle, I was able to max out my timing, and that was with a GT3076 and a 0.63 rear housing. If you have a 0.82 rear housing I'm sure that you won't see any gains with the bigger nozzle.
Hmmm yep have a 0.82 rear (GTX3071R). Now I'm confused, I don't want to drain the WM unnecessarily.
Edited by JustinP
have you got a controller ?
as my 5 1/2 L tank dose not empty twice as fast with a controller.
alot of this is trial and error till you find what works for you and your set up running a duty cycle of 7 on the controller works for me which is over 375ml for me at 322kw@820 nm
with a hks 3037 pro s .87
Edited by WARLORD
Yep I have a fully variable controller.
then you have nothing to worry about.
some people use the cheaper stuff and have problems with wastage.
your going in the right direction its not rocket science as some make it out.
its all going to come down to the man who tunes yor car
what set up did you get and what psi pump did you get ?
is it of tps or psi the controller
Edited by WARLORD
I will be using a Snow Performance Stage 3 kit with the digital variable mapping controller (based on injector duty and MAP inputs). The pump is 220psi.
you have nothing to worry about you will be happy in the end.good system
Edited by WARLORD
Im looking at this kit also. Will be interesting to see how you go
Thanks GTSBoy, thats some conclusive information right there.
Obviously we wouldnt define that as a change in dynamic compression but it obviously has a similar effect to an increase in dynamic compression. Pushing the piston down as it expands (like increased DCR would).
Hard to define, but this is what I was on about the first time I said it. Its interesting to read that it doesnt expand during compression stroke, as I thought it did.
This is a pretty valuable thread.
Just proved in practise again my thoughts that unless the engine is knock limited there is no gain in wmi.
We lost over 65hp on a 1014hp engine with wmi on - that was with a snow performance kit 50/50 mix. That was on a 434ci chevy v8 with f1 supercharger non intercooled on e85.
WMI with E85?
Dont even know why you bothered
It was non intercooled running around 22psi of boost. The measured intake air temp reduction on a 6sec run was around 15degree C at the rev limit. From around 75 to 60degree C. The wmi injector location was at the outlet of the supercharger.
This was a low compression engine (8:1) and was not at all knock limited hence there were no gains with wmi even though the intake temp was reduced by 15degrees.
How much did you inject Rob? Being a 1000hp engine I can see how you would have lost power if you were using a large volume (800cc or so), because as you said ... not knock limited. But a small nozzle pre-supercharger would have given you the air temp drop without slowing down the burn as much.
+1 There is sooooooo much info on the interwebs stating that you do one or the other, just a waste of time to do both.
I really need to pull my finger out and finish my install :(
you sure about that?....and you Manuel Kasko?..you know theres still reason that you would use both even if it made no
more power...not all people just drive around the streets in there skylines you know, theres many forms of motorsport out there...
cheers
darren
Don't wait, it s a good system. I am wrapped in mine - going to keep using it in my RB30 when i get it happening as well. I've got my trigger setings at 6/10 and 50/70 and seems to work about right. I could lower the settings, but will check them out in summer first.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
