Overall though don't be surprised if it's still a bit lazy'laggy even after a tune.
As scotty said a 100m cooler, is not really a smart choice regardless of price.
Probably would've been better to sell and buy something more appropriate.
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6297893
I would just put the stock intercooler back on. If everything else is standard that was not a good first choice of modifications.
Yeah just got the car so goin to get a boost controller nxt week wat u reckon it's safe to turn up to with stock turbo
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6298622
I always liked the stock cooler with the stock or R33 turbo on the RB20.
If you dont plan to do many mods Id just put the stock cooler back on and sell this one like the guys are telling you.
An R34 sidemount will be a good upgrade for it and will be a good match to the stock turbo on say 12psi. You will probably get away without a tune too, just put it on a dyno to check AFR's and keep rocking.
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6299580
The car is almost stock. Splitfire coil packs full kakimoto exhaust everything else is stock do u guys reckon a 600x300x76 fmic is to big
Well you may as well leave the 100mm in now that it's installed , wind up the boost to 12 psi and see what it feels like.
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6299976
Intercooler upgrade is a supporting modiication, not a power one. It's a modification you perform when you are planning big power upgrades (bigger turbo, aftermarket ECU etc.). If this is not what you're aiming for, then it will probably hinder you more with lag than it will benefit you in keeping the intake charge cool. The standard intercooler has been matched perfectly to the standard engine and will be doing a fine job of the latter - bigger intercoolers with more piping generally result in a laggier feeling engine, but are great when you start pumping more and hotter air through the intake system.
That said, many (myself included) report better performance (or more correctly, a lack of "lost" performance) operating in hot environments and under heavy load after installing an FMIC without tune or power upgrades.
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6300039
Don't listen to these homos, you have the cooler now go get yourself a t67 turbo, a highmount manifold and plazmaman intake..maybe an 80mm throttle body too..chuck in a motec engine management system and 2 big bottles of Nos.
Wind boost up to 2 bar and enjoy :D
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6300046
Or you could weld the actuator shut?
Cheaper and more efficient
https://www.sau.com.au/forums/topic/396491-front-mount/#findComment-6300267
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
