  • Replies 7.5k
Posted Images
lol, yeam ummmmmm thanks to your water pump shitting itself, my car (white stagea) wasnt ready for pickup....... just needs the tune. I thoughtfully pre-shat my waterpump so it was actually replaced yesterday. lol.
damn.
nice gtr by the way.
leaving my car there till friday arvo (wife will have to drive it, nooooooooo); they will rip out the 'cooler piping for me and lip the edges of the piping so it doesnt ever pop off in future, then tune. wont be able to drive for a month tho; kneecap out 7am tomorrow. dang.
spotted a white stagea this morning going up torrens rd, and on the way home spotted a white r33 on salisbury hwy and a silver r33 near my house
If it was early morning like about 7:15ish and somewhere near where churchill rd joins torrens road then that'd be me :P
Just on the way to work :unsure:
Saw a black R32 GTR continuing up main north road at the gepps x intersection. Had a couple stickers on it... I waved to the guys in there (dunno if they saw) and then continued up Port wakefield rd.
-D
If it was early morning like about 7:15ish and somewhere near where churchill rd joins torrens road then that'd be me :domokun:
Just on the way to work :w00t:
it was about 10ish in the morning
also tonight on my way home saw a couple of 32's and 33's
saw 'flirty 2' black or blue r32 on main nth road bout 20 mins ago.
Saw white 33 go past bunnings modbury bout 6ish tonite, sau stickers front and back. Seen it a few times, not sure who it is?
spotted a black 32 gtr at pine av / bonython av roundabout about 1pm this arvo
jeff from TSL drivin thru there in his RB20 R31 bout 2 hours before that
Kye drivin down anzacs near kmart this arvo bout 4 (f**k that rain hey)
and a 32 GTR bein followed by a 32 GTST at morphett / seacombe road roundabout about 6ish
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
