  • Replies 7.5k
Posted Images
spotted heaps today
xxR 033 white 33 on sr donald bradman this morning
Nightcrawler on the freeway in the Honda (sorry mate, took awhile for me to realise it was u, haha)
Silver S3 33 GT-R on the freeway towards the tunnels
Silver R32 GT-R at mt lofty
White 32 on west tce
thats all i can remember for the moment
Only spotted a few imports over the weekend while away.. black 33 'xcite' up mount Gambier and then on the way home in Tailem Bend. Also red 32 gtr i think it was with plates 'Ching'.
And on west tce/anzac bout 6ish gunmetal grey 32 GTR. got a wave.. anyone on here?
yeah that was me in the gumetal grey GTR.... :rolleyes:
i think i mite have seen bezenders car on a few occasions around the seacliff park area............seen ya in the morning a few times a couple of weeks back driving along seacombe road about 7am
bout 5ish down the bay, spotted '2smooth' black 33, waved at ya trent but was walking so u probly didnt see me..
just now (6pm) on marion road, black 33 with gold centred dished rims, HOT! Exchanged thumbs up.. if u on here, love your car! :dry:
Yeah that'd be me, im in south brighton. off to work at about 7am (if i cbf'd getting out of bed) :(
Saw Evil 34 on goodwood rd just b4 springbank rd a bit after 5 today. car looks sweet mate :whoops:
spotted a red r34 4 door in salisbury just a little while ago
Today was S13 day. Saw around 7 of em. Saw either an S13/S14 with aftermarket mags, a phat paintjob and 'silvr-1' plates while heading west on Cross road near Goodwood. dude was lookin at gtr while having a cruise with his lady friend, I nodded back... if ur out there mate, nice wheels.
The highlight of my day tho was seeing a deep purple XR6 with 'grimace' as the numberplates. How apt. Looked awesome tho
-D
Edited by Dohmar
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
